Tim-s Posted December 10, 2024 Posted December 10, 2024 So the rear and is completed now so I’m moving onto the front it’s had all new Bara motorsport diff with tightened LSD rrfurbed driveshafts New bushes new rose joints with new sleeves new Damperman shocks new discs and pads new ha brake cables powder coated arms refurb rear chassis new nuts bolts and washers new fuel filter new cabling and protection new gearbox rear seal whilst all was out 9 Quote
aeg Posted December 10, 2024 Posted December 10, 2024 @Tim-s looking good now you know what your doing a ny chance you can pop around and do mine cheers Andy 2 1 Quote
Naranja_Al Posted December 10, 2024 Posted December 10, 2024 30 minutes ago, Mole said: Or mine.. Wow, that’s a serious amount of work to remove an FW diff 1 Quote
Mole Posted December 10, 2024 Posted December 10, 2024 2 hours ago, Naranja_Al said: Wow, that’s a serious amount of work to remove an FW diff Yep.. When not eating turkey over Christmas plan will be to start getting it back together! 1 Quote
Tim-s Posted December 10, 2024 Author Posted December 10, 2024 3 hours ago, Naranja_Al said: Wow, that’s a serious amount of work to remove an FW diff 23 minutes ago, Mole said: Yep.. When not eating turkey over Christmas plan will be to start getting it back together! 3 hours ago, Mole said: Or mine.. 24 minutes ago, Mole said: Yep.. When not eating turkey over Christmas plan will be to start getting it back together! Hi @Mole What was the reason for removing all the rear bodywork Quote
Mole Posted December 10, 2024 Posted December 10, 2024 1 hour ago, Tim-s said: Hi @Mole What was the reason for removing all the rear bodywork I thought that was the easiest way to get the diff out.. I had to get the tank out first..which meant I had to lift the rear bodywork, which meant taking the arches off first.. I could only lift the bodywork a certain way because of the roll cage..which meant removing seats, inner panels to get at the roll cage nuts.. then lift the rear bodywork off... Then tank access was easy, then remove tank carrier frame, which m ant undoing wishbone bolts.. then removing fixed brake pipe from one side..then removing diff studs.. Have taken suspension arms off to clean up too and replace metalastic bushes... And clean up calipers whilst off and replace brake pads...also a good opportunity to check over all the chassis..which looks in good condition.. Quote
Tim-s Posted December 10, 2024 Author Posted December 10, 2024 16 minutes ago, Mole said: I thought that was the easiest way to get the diff out.. I had to get the tank out first..which meant I had to lift the rear bodywork, which meant taking the arches off first.. I could only lift the bodywork a certain way because of the roll cage..which meant removing seats, inner panels to get at the roll cage nuts.. then lift the rear bodywork off... Then tank access was easy, then remove tank carrier frame, which m ant undoing wishbone bolts.. then removing fixed brake pipe from one side..then removing diff studs.. Have taken suspension arms off to clean up too and replace metalastic bushes... And clean up calipers whilst off and replace brake pads...also a good opportunity to check over all the chassis..which looks in good condition.. Ahhhh Got ya I managed to remove the tank through the rear boot area once removed have a good amount of space Quote
Mark19691 Posted December 10, 2024 Posted December 10, 2024 11 hours ago, Tim-s said: So the rear and is completed now so I’m moving onto the front it’s had all new Bara motorsport diff with tightened LSD rrfurbed driveshafts New bushes new rose joints with new sleeves new Damperman shocks new discs and pads new ha brake cables powder coated arms refurb rear chassis new nuts bolts and washers new fuel filter new cabling and protection new gearbox rear seal whilst all was out Nice job, have you replaced the rear bulkhead, if not what product did you use to degrease and clean? Thanks in advance. Quote
Tim-s Posted December 10, 2024 Author Posted December 10, 2024 Just now, Mark19691 said: Nice job, have you replaced the rear bulkhead, if not what product did you use to degrease and clean? Thanks in advance. 1 minute ago, Mark19691 said: Nice job, have you replaced the rear bulkhead, if not what product did you use to degrease and clean? Thanks in advance. Hi @Mark19691 I used de-greaser and lots of elbow grease it came up really well TBF 1 1 Quote
RickRack Posted December 10, 2024 Posted December 10, 2024 I carried out a front end refurb last winter & brought all parts, shocks - springs - powerflex, fixing etc for both front/rear so I’m planning rear end refurb for this winter. But now fear the bar is set sooo high I need a pole-vault. Looks the dogs dangler's… Hope mines looks half that good come mid-March 1 Quote
Tim-s Posted December 11, 2024 Author Posted December 11, 2024 8 hours ago, RickRack said: I carried out a front end refurb last winter & brought all parts, shocks - springs - powerflex, fixing etc for both front/rear so I’m planning rear end refurb for this winter. But now fear the bar is set sooo high I need a pole-vault. Looks the dogs dangler's… Hope mines looks half that good come mid-March Thankyou @RickRack it was a lot of work but worth it. it all started from the diff upgrade to LSD. Quote
