Seight for sale
Oldhens
Does anyone know this car? I’m hopefully going to view it shortly but would appreciate any info if someone’s familiar with it. I believe a couple of previous owners were former member. BX11UEV
Link to comment
  • Oldhens changed the title to Seight for sale
It was once owned by ex-member @cjdad76 in Gloucestershire until he left the club in mid-2020.  Apart from that, there’s a few threads regarding track days, various wheels and a radiator that needed changing, there’s nothing else of interest.
Link to comment
Hi,
Thank you that’s really helpful!
I’ve read through the previous owners posts and one thing that concerns me is a mention of the tub being mis aligned. Is this something to be concerned about, is it something that’s easy to rectify, I guess not as I believe it’s drilled and riveted to the chassis?
Link to comment
Apologies, probably too technical a question for this sub forum, I’ll start a new topic.
Link to comment
1 hour ago, I-16 said:
Hi,
they’re all like that.
the only way to get a decent panel gap between the bonnet and scuttle is the fit the tub off centre.
If you’re in any way OCD don’t measure the widths of the rear arches or the difference in height for the rear lights 😀
  • Haha 5
Link to comment
No need, that’s rather a “how long is a piece of string?” question, in that one man’s “misalignment” is another man’s “within reasonable tolerance”.  The bodies are riveted on, but they didn’t come out of the moulds straight to begin with.  Quite often (mine included) the rear tyre positions left and right are not identical due to this, one being slightly further forward or back in the wheel well.  Just bear it in mind when you look over the car, checking the straightness of gaps between the bonnet, nose cone and scuttle.
Link to comment
I've been pretending not to notice this on mine for over a year now.
  • Haha 4
Link to comment
Sadly whoever built it did it “by the book” and took the build manual as Gospel 🤣
I ended up building mine “by eye” which meant throwing away the rule book but I ended up with balanced looking wheel arch alignment.
But getting all of the shut lines looking good just seemed impossible (replace the “u” with an “i” in shut lines to be more accurate)
As others have inferred it is something that you tend to ignore once you start to enjoy the car for what it was designed to do (make you grin) 😁
  • Haha 2
Link to comment
It’s an SEiGHT. A car you buy for the sounds, the smells, the torque, the grunt. An absolute weapon of a car. I’ve never looked back at mine and thought about things such as panel gaps. I’ve only looked back at it and thought - wow - that’s awesome!
  • Like 7
Link to comment
Thanks for the feedback everyone, so helpful!
I’ve noticed one other concern, it’s using a little water, apparently a slight weep from the core plug before it warms up. Is there anything I can check to verify it’s definitely just the core plug rather than the block has become porous? Are the core plugs easy to access or will it mean lifting the engine to access?
Link to comment
In my experience, if a block has become porous or has a crack, it leaks after it’s warmed up as the block / crack expands.  A core plug will expand as it heats up, getting tighter in the block.  While changing a core plug is generally not difficult and a core plug is cheap (plus cost of fresh coolant), it rather depends on which one it is (there’s more than one) and what might be in the way of accessing it to change it.  You might well have to remove an exhaust header or ancillary, or need access to a ramp, in order to get at it.
Well done on doing comprehensive research before buying.
  • Like 3
Link to comment
Make sure that it's not going into the oil.  Check inside the oil cap for mayo.
D
Link to comment
Thank you. I do have a ramp and happy to do most jobs but just don’t want to pay decent money and immediately have problems to fix. I’d at least like a few months of enjoyment before I have to start fixing things!
I usually do so much research that the car is sold by the time I’m satisfied, I better book the viewing now!
Link to comment
I developed a nervous twitch after trying to get mine square. Don't get me started on the rear lights - if like me you think a laser level is a good tool to use to get them aligned, don't bother 😂😂
  • Haha 3
Link to comment
Have you progressed??  You won’t regret it. Fantastic fun.
  • Like 3
Link to comment
