BEN99W Posted March 23, 2004 Posted March 23, 2004 My ZEi has the inertia real seatbelt, and I would like to fit a harness. However having had the boot box out there are no additional mounting points on the chassis to accomodate the other shoulder straps. would it pass an MOT or be safe to attach to the roll over bar as an alternative? Any thoughts appreciated... Quote
scooby Posted March 23, 2004 Posted March 23, 2004 There should be mounting points on the chassis, I have just done this exercise on my SeiW. What year is your car.... Quote
adhawkins Posted March 23, 2004 Posted March 23, 2004 The ZEi is a 'special edition'. ISTR someone else running into the same problem, and having to have the mounting points welded to the chassis. Yep, look here. Andy Quote
BEN99W Posted March 24, 2004 Author Posted March 24, 2004 There should be mounting points on the chassis, I have just done this exercise on my SeiW. What year is your car.... Its a 94 ZEi - and there certainly arent any lugs for fitting a harness to, although I do have lugs for the RAC roll bar... Welding bits in seems like a big pain in the A*** as I guess the whole area need to be stripped down... maybe i'll just have to avoid crashing. Quote
Blatman Posted March 24, 2004 Posted March 24, 2004 Not a complete strip down. Boot box out and rol bar off should suffice. Westfield sell the bosses, and they're cheap. Anyone even half way handy with a mig welder will have 'em welded on in about 10 minutes....... do it..... Quote
Mark Stanton Posted March 24, 2004 Posted March 24, 2004 Don't fudge it - get the lugs welded in and harnesses fitted correctly How much do you value your life seat belts can save them - if fitted and worn correctly Quote
Tigger Posted March 25, 2004 Posted March 25, 2004 Funny enough, I'm having lugs welded tomorrow. Lugs cost £1.00 each from Westfield's. Quote
