pistonbroke Posted March 19, 2004 Share Posted March 19, 2004 Hi Hope you can help ! Removed the complete windscreen to fit press studs for a tonnoue . Thought it would go back in the correct place, but just noticed that the holes drilled in the body to take the support pillars are elongated. I know , I should have marked it before removal. Is there a standard measurement for the distance from some reference point on the chassis ? (I also have a hood fitted so has to be in the right place) tia Quote Link to comment Share on other sites More sharing options...
Eccentric_Rich Posted March 19, 2004 Share Posted March 19, 2004 Is there a standard measurement for the distance from some reference point on the chassis ? No not really, it depends who fitted the hood. I would fit the windscreen and pillars (but not fully tighten the bolts securing the pillars to the scuttle. Leave the side screens off at this stage. Fit the hood to all the press studs on the rear bodywork and the screen, move the pillars to tension the hood (not too tight as the vinyl will contract when it gets cold and possibly crack the screen) and tighten the bolts when you're happy with it. Richard. Quote Link to comment Share on other sites More sharing options...
Robin Posted March 19, 2004 Share Posted March 19, 2004 Build manual dimensions are 1008mm, fixed R/W Arch or 1012mm, detachable R/W Arch measured from top inside face of windscreen to chassis cross member behind seats. Robin Quote Link to comment Share on other sites More sharing options...
pistonbroke Posted March 20, 2004 Author Share Posted March 20, 2004 Thanks for the advice Looks fairly critical measurement ! I think it might be best to set it up then offer the hood up and maybe then have to re adjust. I dont know for sure how exact the build was. Robin Is that measuring from the glass or from the Ally frame Quote Link to comment Share on other sites More sharing options...
Andrew Posted March 20, 2004 Share Posted March 20, 2004 I could send you a scanned in diagram, would put it on here but g/hosting seems to be down. Quote Link to comment Share on other sites More sharing options...
pistonbroke Posted March 20, 2004 Author Share Posted March 20, 2004 Thanks Andrew you have a PM ( I hope) Quote Link to comment Share on other sites More sharing options...
Andrew Posted March 20, 2004 Share Posted March 20, 2004 Yep, its on its way. Quote Link to comment Share on other sites More sharing options...
