Westfield tire size & offset question
I will buy a custom wheels to this company
  http://www.kodiakracingwheels.com/
I like to use a wide 13 inch tire in the rear
   and small in the front.
I plan to use Kumho tire ECSTA V700 235/45VR 13
  at the rear and  205 in the front.
http://www.kumhomotorsports.com/products/index.htm
Questions:
1.   If I will custom a wheels, what will be the wheel offset at
       the rear?
2.   Can I use 235/45 tire size to Westfield ?
         (approx 9 inches wide)
How much power have you got?
Unless you've got monster power 250+ I wouldn't bother.
You can fit wide rubber like this if you get the wide rear arches (wider than standard SEiW) assuming that you have detachable arches, other wise your looking at cutting & filling & a paint job.
I'd have thought the 215/50VR13 would be more appropriate, although these tyres may be better suited to heavyer cars, you might be better off with A032's or A048's
Click here for all you need to know about offset's
andy ;)
Max baxk space you can get away with at the rear of a SEiW is 5" which is 0 offset on a 9" rim
I will be putting between 350 to 370hp (turbocharged Busa)
So, I cannot use 235/45/13  in the rear?
So what is the most size (maximum)I can use?
.....and also can someone tell me the offset measurement I can use to  a wide wheels.
Read the above. :bangshead:  :bangshead:  :bangshead:  :bangshead:  :bangshead:  :bangshead:
Yep! I will be putting that power, maybe 400hp with nitrous
bl**** hell I hope you can drive mate :p  :D  :p
