5 3/4 led headlights
Please show me your 5 3/4 led headlights
I have alittle project on the go and fancy some led inserts
Anybody had any problems at mot with some of the cheap motorbike led lights?
Posted (edited)
@Rednop1
Fitted these 5 years ago. Cost £65.79 from EBay, unsurprisingly no longer listed!
No manufacturers name on them.
Sidelight is between the two lower circular lenses.
No problems at MOT,  checked on beam setting device and pass ok, garage is thorough but Westfield friendly.
Edited by Alan Cutler (Adge) - Dorset AO
Clarified sidelight position
Fitted these again from flea bay. No problem with mot. Significantly better than the previous halogen lights.
Ebay specials. Not done mot yet though...
I have the same as GaryD1971, past the MOT last month, no problems
Not a fan of the LED ones like above with the smaller round lenses inside myself,just look too modern/put of place on a seven imo😏
These work well,but don't have a side light.
DRL could do with a bit bigger, but think they suit a seven type car much better 👍
These were from Original Cafe Racer, but I think similar are now on Ebay at ~£26 each. No problems so far, went through MOT fine. Centre bar is DRL.
I’ve fitted these off eBay but come with no side light - I’ve now brought the control board from Powerful UK Ltd (also on eBay) - DRL’s now fire up on engine startup & remain on for 30 secs after switch off - the Orange LED’s are wired to existing front indicator wiring (not thru control board) so nosecone pod indicator & LED’s work together. When switching on side lights, this drops supply voltage to DRL to 5.5V (which is quite dim!) but does create a sidelight as the the DRL is dipped & main beam work fine.
In comparison to original candle lamps, these are great in South Staffs villages.
Haven’t yet hard wired (current just use DRL as sidelight) & haven’t taken through MOT yet (Jan 24).
On 06/11/2023 at 21:50, Alan Cutler (Adge) - Dorset AO said:
@Rednop1
The two circular lenses at the bottom provide sidelights.
Do you have side lights?
How do you get thru MOT?
do you have side lights?
No. I have wired the DRL to be a side light when stopped but I always drive with dipped beam on anyway as the car is so dark and low.
Yes. Not brilliant pic, but it does show the led sides. Not connected to the ignition, just the normal switch.
