DMc Posted June 8, 2023 Share Posted June 8, 2023 298mm 85 ohm empty 5 ohm full £20 plus post Link to comment Share on other sites More sharing options...
fildyke Posted June 8, 2023 Share Posted June 8, 2023 Hi Do you know if this will fit an fw fuel tank. If so I'll take it Cheers Phil Link to comment Share on other sites More sharing options...
DMc Posted June 8, 2023 Author Share Posted June 8, 2023 I’ve no experience with the FW tank sorry. It’s a standard VDO bolt pattern if that helps Link to comment Share on other sites More sharing options...
fildyke Posted June 8, 2023 Share Posted June 8, 2023 Ok, I think it will fit, I have a standard vdo float type but want to change to a dip type so that I can put some tank foam in to reduce fuel surge. Ill take it and see if it fits. Can you pm me your details. Cheers Phil Link to comment Share on other sites More sharing options...
