Andrzej Posted February 1 Posted February 1 Fabricated longer clutch pedal instead of previously intended hydro change clutch major rebuild.. Calculatiions said IT will be 15-30% less efforrt on foot and it seems it is closer to 30 or more. Extended 4cm . In calculatiions 3cm. (Some time ago i thought it is good idea to fit sport clutch and clutch plate both helix with 200hp zetec and 240mm rear slicks....its not needed ! . Ended with metacarpal bones fatigue fracture...ouch... ) Easier to lenghten pedal so no engine and gearbox out to change clutch plate to standart or modifiaction to hydraulic) Longer pedał travel , yes ! But seems acxeptable do far Edit - i have also shortened clutch realese arm in gearbox , not helping with pedal efforrt. stationary. Will see on track if it works. 1 Quote
Mole Posted February 1 Posted February 1 46 minutes ago, Andrzej said: Fabricated longer clutch pedal instead of previously intended hydro change clutch major rebuild.. Calculatiions said IT will be 15-30% less efforrt on foot and it seems it is closer to 30 or more. Extended 4cm . In calculatiions 3cm. (Some time ago i thought it is good idea to fit sport clutch and clutch plate both helix with 200hp zetec and 240mm rear slicks....its not needed ! . Ended with metacarpal bones fatigue fracture...ouch... ) Easier to lenghten pedal so no engine and gearbox out to change clutch plate to standart or modifiaction to hydraulic) Longer pedał travel , yes ! But seems acxeptable do far stationary. Will see on track if it works. I like that you have adjustment on the pedal Quote
Andrzej Posted February 1 Posted February 1 Thought it might be needed but ended with shortest adjustment so far . Will see in real life . But worth to have as possible as achievable adjustment . Saw that in racing cars form 50th or 60th Like that idea GDK Legend 6 or DMO Legend 6 had that type od design of all pedals . Old Scholl Racing design Quote
Mole Posted February 2 Posted February 2 11 hours ago, Andrzej said: Thought it might be needed but ended with shortest adjustment so far . Will see in real life . But worth to have as possible as achievable adjustment . Saw that in racing cars form 50th or 60th Like that idea GDK Legend 6 or DMO Legend 6 had that type od design of all pedals . Old Scholl Racing design Quote
DeanMegaS2000 Posted February 2 Posted February 2 Helped my brother change the worlds most ridiculously placed thermostate 1 2 2 Quote
7Westfield Posted February 2 Posted February 2 I can't tell from the picture, but I'm guessing Audi ? they have a rep for that Quote
DeanMegaS2000 Posted February 2 Posted February 2 1 minute ago, 7Westfield said: I can't tell from the picture, but I'm guessing Audi ? they have a rep for that Yeah, its a Q3 2.0tdi. We thiught it was either front end off or remove the intake manifold. We felt the front off was the less risky option for us 1 Quote
Craigieboy Posted February 2 Posted February 2 2 hours ago, DeanMegaS2000 said: Helped my brother change the worlds most ridiculously placed thermostate All part of the bigger plan..... to stop us tampering! AKA saving money. 1 Quote
Andrzej Posted February 2 Posted February 2 WOW, just to get to the thermostat?!?!? I wonder how much they charge for that in an Audi service… BTW — I don’t know how it is in Audi, but some time ago I had to replace the thermostat in a Mazda 6. It was the new intelligent electronic type. Luckily it was still under warranty, but if not… guess the price for “saving the climate” with that intelligent thermostat (BTW, it landed in the trash after 2 years). That’s not exactly saving the planet, I suppose… It was around 600 GBP for the thermostat itself. In Mazda, I don’t think access to it is that ridiculous — at least from what I can see doing oil/spark.filters.brakes change - easier than in kitkars , those cars seem to be designed not to be destroyed during servicing… but I’m not entirely sure how about parts like thermostat... . 1 Quote
Andrzej Posted February 3 Posted February 3 going on with making my track westfield road (almost ) legal ... got headlights and hosings (aliexpress). Unfortunately, due to my own oversight, I ordered two pairs of lamps instead of one pair A few small modifications were needed right away — the screws securing the lamp housing bracket were sticking into the inside of the housing, which made it impossible to fit the insert (the actual lamp). They had to be mounted the other way around, with the rounded heads facing inside the housing and the nuts on the outside. And yeah… they’re kind of big and heavy compared to my previous “lamps,” which I made myself from LED strip, an aluminum tube, and duct tape Ideally, lightweight, smaller Dominator-type LED headlights with built-in sidelights would be best. Unfortunately, I couldn’t find any. I did find Dominator-style lights with an LED DRL ring, but without sidelights. Maybe on the next attempt. I spent so much time drilling different elements to reduce weight, and now these bricks sit high and far out front — the worst possible position for ballast… But hey, it will be the same in that area as a brand-new Westfield SE.NA! (just faster ) 3 Quote
mega ade Posted February 22 Posted February 22 I was hoping to get on with some of the many jobs to do on my westie today but my little grandson wanted me to build his mclaren 287 pieces later complete perfect colour for a fast car and just like any car rebuild a pile of bits that go nowhere but did have some time left to get started on my toy. 4 Quote
eggontoast Posted February 23 Posted February 23 Interested to hear how they are @DannyTGS. I discovered to my dismay last night that the R888s on my 13" wheels seem to have perished in the time my car has been off the road these past ~18 months, and 205/60r13 R888Rs seem to be unavailable. Unless buying part worns from TyreTek (tempting). Quote
mega ade Posted February 23 Posted February 23 7 minutes ago, eggontoast said: Interested to hear how they are @DannyTGS. I discovered to my dismay last night that the R888s on my 13" wheels seem to have perished in the time my car has been off the road these past ~18 months, and 205/60r13 R888Rs seem to be unavailable. Unless buying part worns from TyreTek (tempting). Wow I've not seen that before in such a short time I purchased new 205 60 13 r888rs just 6 months ago from jd competition tyres £136 each and £8 delivery for all 4 when I spoke with the guy on the phone he said he had plenty in stock and they took 7 days to arrive hope this helps. 1 Quote
DannyTGS Posted February 23 Posted February 23 1 hour ago, eggontoast said: Interested to hear how they are @DannyTGS. I discovered to my dismay last night that the R888s on my 13" wheels seem to have perished in the time my car has been off the road these past ~18 months, and 205/60r13 R888Rs seem to be unavailable. Unless buying part worns from TyreTek (tempting). Toyo no longer supply the Uk, some companies will order container loads, these took so long to arrive hopefully having a drive out soon and track day in April too so will try to think on to review Quote
