Paul Hurdsfield - Joint Manchester AO Posted December 5, 2025 Posted December 5, 2025 On 01/12/2025 at 20:08, Ian Kinder (Bagpuss) - Joint Peak District AO said: It does indeed look a great idea, however I share you concern that compared to a press, you may struggle to get sufficient force onto the bushes, via a M10 thread- some good details here- Thread forces I made my own many years ago using m12 threaded rod and spacers. I stripped the thread As others have said it takes quite a lot of force to shift them. 1 Quote
Popular Post DavidMiller Posted December 23, 2025 Popular Post Posted December 23, 2025 So finally had a chance to get into the garage to sort the worn bushings out and try the tool i made. I made a couple of modifications including adding clearance where it butts up against the wishbone as some have larger welds than others, and also to make a custom nut with a very long thread to try to avoid stripping threads. This also makes it easier to use as a socket no longer needs to fit in. I can confirm that it worked - I knew two of the bushings were worn, but ended up replacing five as I found some of the others were worn. This was all I had to hand and I haven't even started on the rear suspension yet. Photos are the tool with modifications, the tool in use for removal, and the end result with the removed bushing on the tool. Installation was easier than removal. I changed the front upper bushings on the car without removing the wishbones so it ended up being relatively easy. I don't know why this worked when others have needed so much force for removal, but there was no significant rust at all so maybe that made it easier? 10 1 Quote
mega ade Posted December 23, 2025 Posted December 23, 2025 Well done excellent tool your decision to make that extra long threaded nut is definitely the key to success with this ive heard others using similar tools that rely just on a standard nut have failed with stripped threads 1 Quote
Mike Rowland - Essex AO Posted December 24, 2025 Posted December 24, 2025 Great, still want one maybe your bushes were pressed in originally with a little grease or copperslip (think I did this with mine) 1 Quote
DannyTGS Posted December 30, 2025 Posted December 30, 2025 Ignore the red tape, Didn't have any black, But ill thread it through loom corrugated section once I get some from work, but now I have reactive brake lights lol And while I was at it, little extinguisher install 5 Quote
aeg Posted December 30, 2025 Posted December 30, 2025 @DannyTGS well done for fixing your brake lights after @Ian Kinder (Bagpuss) - Joint Peak District AO commented on them on Sunday he will be pleased to know I’ve put new bulbs in Becky’s car as well so that just leaves @Julie Hall - WSCC AO Representative !!!! Has Glen fixed them yet ? I should hope so …. his got more time on his hands than the rest of us 1 2 Quote
Andrzej Posted December 30, 2025 Posted December 30, 2025 Tight space to work there… hopefully my pressure switches will keep working, so I won’t have to break my fingers trying to fit something similar well one is with hanging pedlas so easier access. 1 Quote
Tim (Sideways) Johnson - Club Treasurer Posted January 1 Posted January 1 Today was the turn of the Spitfire. Replaced the shoes and adjusters on the rear brakes, the dizzy cap, popped a fresh battery on and the old sausage is mobile once more! It hasn’t run well under its own steam since we got back from Classic Le Mans in 2022 with a sticky front calliper. I replaced those earlier this year, but put the Spitfire on the back burner with the arrival of the Westfield. We now have a fully working fleet as I’ve spent my week off doing all the car jobs. 2CV didn’t need anything as it never does, I fitted new discs and pads on the rear of the Volvo (so of course that now needs the EPB coding to behave properly!), the Westfield had an oil and filter change yesterday and a couple of other little jobs and the Spitfire now just needs a good polish and hoover and the brakes bleeding. Van needs an MOT at the end of the month, so that will be next in line. Was going to take the Spitfire for a blat, but it’s just started persisting down, so it’s Netflix and warm up in front of the fire. Happy New Year all! Quote
dvd8n Posted January 11 Posted January 11 Just before Christmas I fitted my new header tank: I had to cut the old connecting hose off and fit a new one: I had to order a new hose clamp which arrived the next day. Then my mother came down with some sort of norovirus thing and my wife came down with flu. Just as they were getting themselves sorted out I came down with some sort of lurgi as well. But, today, I finally got the hose clamp fitted: It only took three weeks David 6 Quote
Popular Post Robin Parker (Red Spider) - Yorkshire AO Posted January 15 Popular Post Posted January 15 Saturday dinner time, sat doing nothing in particular, some friends say they're going skiing, anyone want to join them. An hour later I'm at their house booking it. Monday morning I'm on my way to Andorra for 3 days skiing. 13 years since the last time and 39 from my first time on snow. I've had a great time and can't wait to do it all again next year. This is what retirement is all about. 13 1 Quote
Tim (Sideways) Johnson - Club Treasurer Posted January 17 Posted January 17 Swapped all the clips on the lower coolant hoses from nasty rusty jubilee clips to full stainless Mikalor hose clamps and refilled coolant. This should mean I have a new leak tomorrow and airlocks galore in the cooling system 4 Quote
Tim (Sideways) Johnson - Club Treasurer Posted January 17 Posted January 17 I also swapped the routing of the power supply to the starter as it had been run under a chassis member and clearly been in contact with a speed bump or suchlike at some point. 1 Quote
Ross the Scottish exile Posted January 20 Posted January 20 The doors with this Westy I’m refurbing were very tired looking with tatty edges and faded cloth, the windows wears quite badly scratched in places, anyway I did some repairs using “Shoe glue”. I've fitted some edging and gave them a really good clean, sprayed the material with autoglym spray dye, and then polished the windows with head light restorer and a sponge buffing pad. quite pleased with the result. 7 Quote
Andrzej Posted January 21 Posted January 21 Fitted new.front wilwood calipers with 265 discs and rear Golf 4 calipers with 41mm poston bore. Bleeded . Looking for fluid lekas now 5 Quote
