24 minutes ago, Jaime Ward said:
Winter projects underway, she will be rolling out next year with a new carbon bonnet 😎
Are you making it yourself then? will look forward to seeing the finished item. And your price list 😂
Making it myself, squared up the bonnet as best as possible to make it a bit straighter and made the gaps more uniform, so hopefully the carbon one will fit loads better! Should lose a couple KG's as well!!
Just have to decide on what weave orientation I want to have next, and make the plugs for the vents. Might make myself a couple bonnets for fun, but have no intention currently on producing many. Might put the mould up for sale after I have had my fun though!
  • Like 3
I like the look of a carbon/Kevlar weave.
2nd MOT passed at Stablers Garage.
Just need some new rose joints for the ARB’s.
  • Like 4
Progress on making my trailer Westfield suitable
559843557_18420862612129544_7688200181659730232_n 559666189_18420862603129544_9062050499106151528_n
  • Like 8
Engine and gearbox out! Was planning on leaving the engine in, but needed a few mm extra to for the gearbox to clear the clutch plate. In the end I pulled it all out. Not the easiest on your own with a trolley jack but got there in the end! Committed now to a full chassis refresh, fix some rust, have a few extra bars welded in, etc etc etcccccccc.... And get rid of the rats nest thats the wiring loom. The list continues to grow!!
  • Like 5
That a bmx jump ramp hanging off the wall, @DannyTGS?!
It is yes, but it’s for my RC cars lol
Making a desk that is 142 cm wide fit into an alcove that is 137 cm wide.
  • Like 5
Removed the expansion bottle from my Raceline water rail setup and replaced it with a proper header tank system.
  • Like 9
I've seen the term 'water rail' quite a lot on here recently, I've no idea what that is though or what it does, why it's better etc. Anyone like to explain in simple terms please?
It neatens up the top hose plumbing bringing it to the front of the engine, and replaces the original plastic thermostat housing which can become brittle with age and crack. Looks pretty, too!
The water rail modification on the zetec, essentially removes the long "hockey stick" 90 degree hose from the thermostat housing on back of the engine (in rear wheel drive applications) to the radiator in the nose.
The Zetec plastic thermostat housing is a bit fragile (becomes brittle with repeated heat cycles) and replacements are hard to find so its a common modification.
Here's a water rail from Burtons
Beat me to it! 😂
  • Haha 2
Would this fit a zetec black top?
