11 hours ago, Rhett Turner - Black Country AO said:
I had a similar experience great piece of brick, did not see it until too late, but a dirty great dent in the passenger side steel lowered floor.
I've very glad it was not the same place though on the driver side as that is where the brake and fuel lines run. If I referb or build another Westi I'd not route them as guided they would be all down the tunnel sides.
Thankfully, the XI is meant to have the brake line run in the tunnel, on top of the lower chassis rail. The fuel line goes straight from the tank, which is alongside my right knee, to the engine bay.
Maybe a bit early, but the winter strip down and refresh has begun! Few changes to be made, hopefully next time it comes out the garage in one piece she will be more of a machine! 😁
  • Like 7
Interesting, where have you placed your cold air intake? I'm always interested in how other turbo cars are done differently to mine.
I'm in a similar situation atm though! Started to do one job, then decided may as well do as many as I can given September is closing in.
  • Like 4
The intake on my car is infront the block behind the radiator. My turbo is mounted under the manifold so the intake is relatively low compared to yours.
Is that spoiler a westfield item Steve looks like one of them hot rods
  • Haha 2
I have to have a roof spoiler like that or the Carrot will fly! 😂
I just hope all the work sorts your boost issue lots of sunny days ahead yet
Indeed there are! My next issue after the few jobs are done is the dreaded MOT emissions test!
  • Sad 1
I've started work on assessing the damage done to the XI. This was flat:
The lowered passenger floor has taken a bit more of a beating than I realised, as it doesn't look too bad from underneath. Lifting the seat pad out gave a different view, as I could fit my hand under the gap.
Some how, the chassis has nothing more than a scuff to the powdercoat at the front! There are three rivnuts that spin due to bent bolts, but otherwise the damage is limited to the bolt on undertray and the seat floor. I am rather glad I was flying solo at the time!
  • Sad 3
Good grief @DIY-Si , the XI took quite a beating. Yes, if you'd had a passenger, they would certainly have felt something trying to come through the floor!
  • 2 weeks later...
Full:
Bank account: Empty
  • Haha 5
  • 2 weeks later...
  • 2 weeks later...
Wow ! That is something !
Re flight suits- take it ! and use in Westfield , to drive on hot day or mechanic work, we use similar ,.comfortable, breathable, lot of pockets, and some nomex -  thin but always  better than cotton material.
Changed Winston into his winter plumage, by fitting the 15” wheels with new Uniroyal Rainsport 5 boots on, in place of the 13” R888Rs. Also refitted my half doors and popped the roof on so I’m ready for anything.
It will be interesting to see how different the drive is from a ride and grip perspective. These are 195/50 vs 205/60, at least it should have a bit more grip in standing water, the 888s only have about 2mm of tread left which is fine in summer but….
I also weighed the wheels/tyres to see how they compare. Less difference than I thought. 14.65kg for the 15” with the 195s and 13.75kg for the 13” with 205s.
I prefer the look of the 13” still.
Annoyingly I somehow managed to b*****r the thread on one of the bolts which holds the caliper on (and the bottom of the cycle wing bracket) so will need to source another.
  • Sad 3
