6 hours ago, Benrobson2999 - Kent AO said:
And bonnet holder which folds away when not in use
Are you worried about it losing any shape whilst it's off, or have you braced it in any way?
My FW bonnet splayed out a bit when it was off to do the radiator ducting. I got myself worked up a bit when I refitted mine and it wouldn't close properly, but then I remembered reading about how it was a common issue, especially at shows.
It was fine after a couple of days and I'm sure the more experienced owners have all been through it 😁
  • Like 3
Finished fabricating a bonnet support for the X1. Boot strap, headlight and interior and done!
Sorned and stored, off on a work trip til Xmas
  • Like 4
Cleaned the Westfield and decided to introduce it to my biggest car
  • Like 6
Nice, just don't start the Pathfinder in gear!
  • Like 3
New front grill made from ABS plastic. 285 grams lighter then the original, every little helps!IMG_20241118_104702_MP.thumb.jpg.51ee2145c6d7c31686c40ce360da9dfd.jpg
  • Like 6
That’s smart that how did you do the nice edge?
I agree the edge is nice, but won't be seen. Unless it's inserted into the nose, rather than flush behind the lip.
1 hour ago, Benrobson2999 - Kent AO said:
That’s smart that how did you do the nice edge.
I used rubber edging strip. I think it's 7mm deep left over from another job. It definitely won't be seen but it gives it higher standard of finish. Just a geeky level attention to detail which floats my boat
  • Haha 2
My engine cover hangs on the wall.
Fit x2 horizontal wooden bars to the wall.
Drill x2 holes in the return lip of the engine cover 6in back from the front edge. Out of sight.
Fit x2 wood screws in the top wooden batten that fit in the holes in the return lip. Hangs on the wall out of the way.
Tip always place it no where near where you always walk past.. So you don't knock it off. Keeps it virtually dust free, stops it spreading wider and out the way.
  • 2 weeks later...
Birthday present from the wife yesterday. I was even allowed the time to go and fit it!
  • Like 7
18 hours ago, Kit Car Electronics said:
Took a voluntary redundancy/ early retirement deal so more time to play with cars and buttons (hopefully)
My missus called that ‘retundancy’ when I took it a while back.
I finished on a Friday, had the weekend off then started on the bathroom refurb on the Monday. Beware the ‘job list’ ;)
  • Haha 3
What I have just done?
Swapped a mini!
  • Like 3
