Side wind deflectors from Westfield £160 or some 5mm polycarbonate sheet from work - free to a good home. Stainless liftoff hinges left & right hand - Amazon £12.
I knocked out the hinge pin, machined them to size to suit the windscreen then drilled & fitted a 3mm grub screw to secure. Tried and tested today, much satisfaction in the process of making and the end result IMG_20240707_103134_HDR.thumb.jpg.d782d05cce7adc150682cca5550e1ab2.jpg
  • Like 6
Look fantastic, well done.
Just a pity they're about 3 weeks too late for me. :cry:
Wired up the DRL's.
Used the same controller as I've used on a few Mx5 installs and it's never let me down, though required a couple of resistors to work properly. It was fine with a incandescent bulb, but wouldn't recognise the leds.
Hardest part was threading the cable up through the sleeve to the headlamps, but I was determined to do it.
  • Like 6
Finally got the crash pad recovered and fitted. Fake suede. Looks good at the moment, see how it fares over time
I have enough material to redo it about 20 times!
  • Like 5
Looks fantastic, you can be proud of that. 🙌
You could always cover your costs by using up the extra fabric on other people's cars...😉
Taking pooch for a walk on a lovely mid summer day ☔
  • Like 4
He/she will need a jetwash when you get home! Just make sure you turn the pressure down 😂
Yeah he had a long shower 🤣
  • Like 3
On 30/06/2024 at 17:34, Onliest Smeg David said:
Mountain biked in proper mountains for 1st time.... Austria @ 2000mIMG-20240630-WA0010.jpg.728b8f09eebb4ebb5d70584429ad7898.jpg
Some shakey videos of us (handlebar mounted phone)
  • Like 3
How did you get the YouTube vids to embed? Last time I put a YT link in all I got was the  written link, no icon or anything
In YouTube > play vid > select 'share' > copy link > paste into comments box
Bodged my accelerator cable after it snapped at the pedal. Managed to get home thankfully as I didn’t get very far. If I’d known how it connected I’d probably have been able to fix it properly before my bodge 😆 New cable needed!
  • Like 4
Yeah that's what I did. I suspect it may not have worked immediately because I had literally just posted the vid on YT.
Same thing happened to me in my Tiger yonks ago, luckily I broke down not far from a Halfords so used a bike brake cable. After that I always carried a spare cable in that car. I should do the same in the Flying Carrot really but had forgotten all about it until I read your post, so ta for the reminder 👍
