Rear lights
Benrobson2999 - Joint Kent AO
I fancy a set of these rear lights. If anyone has a set in the garage or fancies a change of light them selves
Lamp units available as above, just not the housings shown in the picture; they are a Westfield-only part, unless you want to pay $ for carbon ones!
Any idea where the carbon ones are supplied?
Proper C/F housings for the side/indicator lamps came from AP Carbon (unsure if Ashley is still an active member on here).  Think they were about £375 per pair, and 6-8 week lead time.  He doesn’t do the single lamp holders.  All the WF ones are carbon-effect ABS plastic.
Ash/Rednop is still very much active on here, see if he still makes them
He’s Rednop1
