mark.anson Posted February 28, 2004 Share Posted February 28, 2004 I have sort of asked this before a while back,but could do with a bit more detail. I am currently installing brake pipes and will be routing the front to rear pipe through the transmission tunnel.Fuel pipe also. I am not sure which route to take from the front brake lamp switch ie should the pipe follow the lower rail of the transmission tunnel or do I run it along the top one and then down the diagonal rail just before the diff flange. Also does the fuel pipe run along the top left hand side of the tunnel. Cheers folks;; any detailed photos or even a sketch would help. Quote Link to comment Share on other sites More sharing options...
Tigger Posted February 28, 2004 Share Posted February 28, 2004 Look here, its stuarts page with some pics of the brake pipe routing Stuarts Page Quote Link to comment Share on other sites More sharing options...
Enterpryse Posted February 29, 2004 Share Posted February 29, 2004 I routed mine to the rear underneath, just like the factory say but a lot of peole do route through the tunnel. Good luck bending ... Stuart Quote Link to comment Share on other sites More sharing options...
deano.1 Posted February 29, 2004 Share Posted February 29, 2004 I routed mine underneath as well and that was enough p*****g about for me lol, Machine Mart do a nice little bender that will do fuel and brake pipe for around £14 Quote Link to comment Share on other sites More sharing options...
