Since I discovered the factory put the LH thread nut and stub shaft on drivers side rear hub and RH thread nut and stub shaft on passenger side rear hub, I have been trying to swap them around, but I can't find any suitable nuts given the Westfield parts shop is no more.   I believe they are M22 1.5 nyloc nuts with 41 mm AF , does anybody know where you can get them ?  Febi produce what they say is  suitable for all sierra's but it says they are  M27 2 41 AF clearly that diameter is too big.  Kit car direct etc don't have any Sierra M22 in stock , is there any other supplier out there who might have them ?
Hi ,Sierra rear drive shaft 41mm nuts are available on eBay [genuine ford ones ],I think its ok to re use as required ,a small amount of thread lock ,torqued  up correctly and a  paint mark on them to check they are still tight after use.
Seen these on ebay a bit pricey! id 234742107433
@Rednop1 @Kingster any ideas as I also need x 2 (1 x LH and 1 x RH)
Got mine off eBay a while back
Thanks Chris @Kingster - gone with the ones @Steve20 recommended as need for next weekend.
 Thanks @Steve20I saw these but wasn't sure they were big enough, are they 41mm across the flats ?
From memory there’s two sizes - I know I once ordered some that were too big for mine, but I have push-in shafts not lobro.
Thanks guys.  I have the ebay ones on standby.   Just placed an order for a pair from GBS( people who make the ZERO)  they claim they are identical to westfield parts and £10 cheaper than ebay.   I will keep you posted if they are any good.
My shafts are with Lobro joints and nuts are 41mm across flats 👍
