mikey p Posted August 11, 2022 Share Posted August 11, 2022 Full set up for front corners. I ran these for years and were amazing on track with a light fast road pad (I used M1144). Never over heated them and they had superb stopping power. I stupidly 'upgraded' and have never had the same confidence as this original set up. Cortina uprights good condition, driver side has one of the small backing plate holes drilled out for a m12 speed sensor. £100 Cortina front hubs, bearing are all ok and genuine ford items will need a clean and check. £50 247mm capri front disks have a small lip but less than half worn. 19.6mm £20 M16 calipers good working order, spaced for the vented disks. Come with some braided brake lines which are serviceable. Can come with some standard QH pads. £75 Almost brand new Q&H cortina track rod ends. Did around 500miles if that. £10 Happy to do the lot as a deal. They are just missing the caliper to hub bolts and locking tabs. A fit and forget set up. Can give to a courier if you arrange. Link to comment Share on other sites More sharing options...
mikey p Posted September 24, 2022 Author Share Posted September 24, 2022 Back up for sale Link to comment Share on other sites More sharing options...
mikey p Posted April 26 Author Share Posted April 26 Still got these for sale. Link to comment Share on other sites More sharing options...
