MOT Certificate
David Oxfordshire
Hello, Just curious if anyone else has had this? Tried to Tax the Westy today but the DVLA Website came up with "MOT test certificate could not be found" and application was cancelled. Any shortcuts to getting this sorted as the number is permanently engaged. ☹️
Link to comment
try randomly pressing no.s in their hold, alot of the time they have a secret number they dont tell you to take you an advisor. I did it once when buying my car, think it was 8 or 9.
Link to comment
Its just permanently engaged so cant even get that far. Car was registered after IVA last year but doesnt need an MOT for another two years right?
Link to comment
It should be 3 years from Iva. But there have been cases where it’s not been setup properly when the car was registered.
what does it say if you put your reg into the dvla online mot checker?
Link to comment
29 minutes ago, Stuart said:
If it's a Q reg I think it needs MoT after 12 months
That’s not correct.
But they will not recognise it online. For the first three years I had to tax mine at the local post office, where they had to fill in a paper form 🙄
Link to comment
Correct
Link to comment
You will have to do it at a post office I’m afraid
Link to comment
Well, for a different take…I did a pre-IVA MOT on mine, and noticed recently that the DVLA website shows the MOT expired 1 year after that pre-test.
I've said before, I have no issue with an annual inspection on a car I built in my shed….particularly when one remembers that IVA and MOT don’t necessarily check the same things, neither am I inclined to fight the system over it.
Link to comment
As @Kingster says you need to go to a post office that does VED with your V5.
Or the other option if you want to is MOT the car,you can then use the on line system.
Link to comment
2 hours ago, corsechris said:
did a pre-IVA MOT
I think that once you MOT it, then you must do so every year thereafter because you are in the system.
Link to comment
Indeed. I was somewhat surprised they managed to connect the MOT done on the VIN with the car, now it’s registered ;)
Link to comment
Thanks for the input everyone. Managed to get hold of the magnificently helpful Ms Dymond at the DVLA and she explained there is a short coming in the "system" linking IVA passes to MOT certificates not being correctly tagged.
Anyway I've sent her a cheque and she is going to tax the car...seems like in 3 years time when it has to have its MOT it will clear the DVLA pipes out!
Link to comment
Correct 😀
Link to comment
