marcusb Posted August 31, 2021 Posted August 31, 2021 I saw a Westy at Stoneleigh with one, does anybody make them?
Dave Eastwood (Gadgetman) Posted August 31, 2021 Posted August 31, 2021 4 minutes ago, marcusb said: does anybody make them? Usually only once! Otherwise, most I've seen have been done by the owner, and usually with one of those carbon fibre skinning kits.
Steve (sdh2903) Posted August 31, 2021 Posted August 31, 2021 @Tim Reid (TimDave25) - Joint Thames Valley AO did it I think? Skinned a bare fibre glass crash pad. Don't think it was easy. 2
marcusb Posted August 31, 2021 Author Posted August 31, 2021 2 hours ago, Steve (sdh2903) said: @Tim Reid (TimDave25) - Joint Thames Valley AO did it I think? Skinned a bare fibre glass crash pad. Don't think it was easy. looked good if it was Tim's 1
marcusb Posted September 1, 2021 Author Posted September 1, 2021 8 hours ago, NickBW said: I skinned mine! @NickBW have you got any pics? I might have a go
Tim Reid Posted September 1, 2021 Posted September 1, 2021 I think it was my car your saw. Here is a couple of pictures and if you go back through the pages you can see some of the work that went into making it. Lots of work but rewarding results.
marcusb Posted September 1, 2021 Author Posted September 1, 2021 43 minutes ago, Tim Reid (TimDave25) - Joint Thames Valley AO said: I think it was my car your saw. Here is a couple of pictures and if you go back through the pages you can see some of the work that went into making it. Lots of work but rewarding results. Yes @Tim Reid (TimDave25) - Joint Thames Valley AO it was you car I saw how much CF cloth did you end up needing to cover it?
Tim Reid Posted September 2, 2021 Posted September 2, 2021 12 hours ago, marcusb said: Yes @Tim Reid (TimDave25) - Joint Thames Valley AO it was you car I saw how much CF cloth did you end up needing to cover it? I bought a meter but had lots spare. I used three sections to cope with the curve. I recommend using wrapping paper or similar to map/template your approach. 1
