Brad Stone Posted June 18, 2021 Posted June 18, 2021 Hi All, On behalf of myself and @Bigchris092, looking for the following: 1 x pair of front cycle wing stays (NOW FOUND - Cortina) 1 x offside cycle wing stay (Sierra SDV stay required!) Many thanks Brads
Ian Kinder (Bagpuss) - Joint Peak District AO Posted June 18, 2021 Posted June 18, 2021 Hi Brad, it may help if you indicate the type of front upright you've currently both got.
Dave Eastwood (Gadgetman) Posted June 18, 2021 Posted June 18, 2021 Yep, there are three/four? types of Westfield cycle wing stay that I know of! Original cast iron Cortina stays. Westfield fabricated upright stays Westfield/Hi Spec alloy upright stays And the ones I'm not sure about, the Westfield Sierra SDV and Mazda SDV kits! 1
Stu Faulkner Posted June 18, 2021 Posted June 18, 2021 4 hours ago, Dave Eastwood (Gadgetman) - Club Secretary said: Yep, there are three/four? types of Westfield cycle wing stay that I know of! Original cast iron Cortina stays. Westfield fabricated upright stays Westfield/Hi Spec alloy upright stays And the ones I'm not sure about, the Westfield Sierra SDV and Mazda SDV kits! Your right Dave, the Mazda SDV ones are different, one can only assume the Sierra ones are as well. 2
Kingster Posted June 18, 2021 Posted June 18, 2021 30 minutes ago, Stu Faulkner said: Sierra ones are as well. Yup. Very!
Brad Stone Posted June 21, 2021 Author Posted June 21, 2021 Thanks chaps - I think @wheelspinhas sorted Chris out with his cortina uprights. Mine is a Sierra SDV - Any advice about which ones I need? Many thanks as always - Picture below: On 18/06/2021 at 18:05, Stu Faulkner said: Your right Dave, the Mazda SDV ones are different, one can only assume the Sierra ones are as well.
Kingster Posted June 21, 2021 Posted June 21, 2021 1 hour ago, Brad Stone said: Mine is a Sierra SDV - Any advice about which ones I need? Errr that’s Sierra SDV then 1 1
Brad Stone Posted June 21, 2021 Author Posted June 21, 2021 18 minutes ago, Chris King said: Found a pic Ha Cheers Chris - What I actually meant to say was... Does anybody know where I can procure said Sierra SDV Stays from?
Dave Eastwood (Gadgetman) Posted June 21, 2021 Posted June 21, 2021 Westfield! There will be the odd other kit manufacturer doing them I suspect, but there’s no guarantee they’ll fit Westfield cyclewings properly.
Craigib76 Posted June 21, 2021 Posted June 21, 2021 I may have a set of these that are new I will take a couple of pics and post them
Kingster Posted June 21, 2021 Posted June 21, 2021 Another pic (with top ball joint / drag link in place) 1
Brad Stone Posted June 21, 2021 Author Posted June 21, 2021 Thank you for sharing some pics @Chris King! No problem @Craigib76- thanks anyway.
