Cadwell 29th july
22 hours ago, Andrew said:
Did you forget your sun dial?
..sorry.. 😉
I think Chris has well and truly chucked his sundial in the skip as he has definitely moved up a gear or two and made it redundant.
  • Like 5
looks like you kept calm and carried on @Andy - a15cro 🙂
Been off there a couple of times myself.. the worst thing you can do is try to fight it back onto the track too quickly. The result is usually smacking the barriers on the left.
Yes @Andrew luckily I was straight enough to keep it going and navigate back on. Hitting the brakes would have been a bad move! The green Lupo was also heading up North as we past each other a couple of times.
4 hours ago, Kingster said:
The Brown Trouser Run
Good footage Chris. I’m going to attempt to do something with mine.
@Andy - a15cro if you try and get the track overlay I’ll bet it won’t be accurate when using the Hero 9 Media Mod.
I’ll post some pics tomorrow to illustrate it, but without the Media Mod I got proper telemetry data. But with it, the telemetry was all over the shop.
I’m going to bin it and either buy a mic adapter or use one of those foam covers - or maybe stick a “dead cat” over each of the mics.
Pictures click the k20 powered x19 to find yours
TDS Cadwell Park 29.07.21
Some great shots, here’s a couple.
IMG_0198
  • Like 4
8 hours ago, Kingster said:
IMG_0198
That's a cracker! 😎
1 hour ago, Andrew said:
That's a cracker! 😎
Gwan boghouse🤘🏿🤘🏿
