Kerglas Posted June 6, 2021 Share Posted June 6, 2021 Wide body roll bar fitted with hood frame ....comes with TWO hoods. One has a reinforced repair on a leading edge corner in addition to the 'grip' that fits the screen has broken where you'd expect..on the mid point mount position. The second hood is the better one...however..it only has two mounting studs fitted..on the front edge...there are none elsewhere so I'm guessing these could be fitted to suit. The pictures show the hoods loose fitted due to lack of fixing studs or that my arthritic thumbs and forefinger couldn't grip to fit. I've priced it at £135.00..PRICED REDUCED TO CLEAR! Delivery best discussed. Link to comment Share on other sites More sharing options...
