Westfield NOS Driveshaft Assembly Left and Right Pair
Pair or Westfield NOS driveshaft assembly units left and right. I believe these are Sierra push in style. I bought them from a guy who had them as spares for racing.
Some light surface rust and marks from storage - see pictures.
The part numbers read;
DL1214
1700043980
and
DL1213
1700043363
3213088
Located in Bristol looking for £300
I can post via courier for £20 if it helps.
No, these look to have Lobro joints on, so are the bolt in types, as used with the Sierra (viscous) LSD etc. They've got the outer stub shafts bolted on, from the look of it, which may be where the confusion has arisen?
Thanks Dave, I was debating whether or not to put the advert in the technical section first to identify them. Fingers crossed they are useful for someone.
The stub axles are around £200 on their own, to buy new, so this is a good buy for the complete package!
@Dave Eastwood (Gadgetman) - Club Secretary - do you happen to know if all Sierra SDV driveshafts are the same length? I believe my car is a “extra-wide” as it copes with the driveshafts from the XR4i
The advertised shafts will not suit a Sierra SDV (that has SDV uprights). The SDV uses (by design) standard Sierra driveshafts - not the shorter ones used in a modular Westfield build.
thanks Chris, although I'm confused now... My existing driveshafts have a Westfield sticker on them, so presumably not OE Sierra
If it helps I have just converted from Sierra SDV to standard SEi rear and still have the old Ford shafts in my garage, could measure tomorrow and give comparative dimensions.
Steve
Just measured my shafts - they are approx 225mm between the tips of each CV boot
Interesting chat gents, does anybody want to buy them? 😂
  • Haha 1
PM sent for drive shafts
Still available
Could you please measure between the CV boots? I might be interested, but obviously only if they fit!
Measuring between the inner faces with them straightened out.
I make the longer one around 370mm and the shorter one around 340mm.
Thanks for checking - just as well you did - my driveshafts are about 380mm and 410mm respectively
