Front springs.
Pair of front springs wanted. 1.9” id, 9” length, 225 lbs. Good condition please, chrome or black.
Or close.
225 lbs fro the front sounds a bit soft John
Is it for a BEC ?
No, CVH. What do you think?
somewhere around 275 and maybe a tad higher depending on what you like.
i ended up with 275 as a nice ride over the rubbish roads we have now, xflow powered here so weights not that dissimilar to a cvh..
Is it a standard track or wide track car as the motion ratio makes a huge difference as to the springs required. 225 is very soft for either with a car engine
I would be using 300lbs to 350 lbs
If you have the adjustment scope I have some 8" 275lb Faulkner springs and am in south Liverpool, not new but tidy enough.
Jim
Jim
Jim, pm sent. 🙂
