Kent Westfield Posted November 20, 2020 Posted November 20, 2020 1 hour ago, Chris King - Webmaster said: As Kev says et0 should fill the arches? also the figures don’t look quite right (diameter?) this is what I see... You are right - I had put 15" for both instead of 15" and 13". But the offset picture does not change very much
CosKev Posted November 20, 2020 Author Posted November 20, 2020 2 hours ago, Kent Westfield said: I’m struggling with the calculations. The wheel does not have the ET marked. Some more photos I'm thinking they could be ET41
Kent Westfield Posted November 20, 2020 Posted November 20, 2020 10 minutes ago, CosKev said: I'm thinking they could be ET41 Could be. Struggling to see how it is 41mm from the rim centre line
CosKev Posted November 20, 2020 Author Posted November 20, 2020 3 hours ago, Kent Westfield said: I measured from the back face of the wheel mounting hub to the front and this was coming to 82.5mm. I did this with the spare wheel by placing it face down, and measuring the depth from the mounting face to the ground. Think you are measuring that the wrong way around?
Kent Westfield Posted November 20, 2020 Posted November 20, 2020 32 minutes ago, CosKev said: Think you are measuring that the wrong way around? I would love to know where I am going wrong. I do think it is probably a 41et but would be good to calculate it as well to be sure.
CosKev Posted November 20, 2020 Author Posted November 20, 2020 14 minutes ago, Kent Westfield said: would love to know where I am going wrong. If you look at the pic I put above you are measuring to the front of wheel,instead of the rear? Back space is from the mounting face to the rear of the alloy, not the face
CosKev Posted November 25, 2020 Author Posted November 25, 2020 50 minutes ago, 1960dave said: 2 weeks are you joking if I knew it was going to take that long I wouldnt have ordered off you. what the devil? Either drunk or replied to wrong thread?
1960dave Posted November 25, 2020 Posted November 25, 2020 Whoops wrong post. I will delete 2 weeks are you joking if I knew it was going to take that long I wouldnt have ordered off you. 2
Rednop1 Posted November 25, 2020 Posted November 25, 2020 6 hours ago, 1960dave said: Whoops wrong post. I will delete 2 weeks are you joking if I knew it was going to take that long I wouldnt have ordered off you. Sounds interesting 1 2
