Black Shadow Posted January 25, 2004 Share Posted January 25, 2004 Can some one help I have just come to fit my rear brake capliers and I think I have the wrong ones. If I where to bolt the calipers onto the rear hubs as per the build manual there is no way that the disk will run between the pads. Am I right in thinking that there are no spacers that should go between the caliper and the rear hubs ? I have a pic of the problem but could work out how to load into the post. If someone has a pic of there rear brakes that might help me. Thanks Nigel Quote Link to comment Share on other sites More sharing options...
Leon B Posted January 25, 2004 Share Posted January 25, 2004 The discs have a big offset so initially it looks like its a long way off but in fact its not. Get a pic up if you can. You need to upload it to your webspace then link to it using the image tags Quote Link to comment Share on other sites More sharing options...
Black Shadow Posted January 25, 2004 Author Share Posted January 25, 2004 Small problem with the loading the pic, I don't have any web space yet ... any other ideas ? Quote Link to comment Share on other sites More sharing options...
adhawkins Posted January 25, 2004 Share Posted January 25, 2004 Follow the link in my sig. Andy Quote Link to comment Share on other sites More sharing options...
scruffythefirst Posted January 25, 2004 Share Posted January 25, 2004 www.photobucket.com is also usefull Scruffy Quote Link to comment Share on other sites More sharing options...
Black Shadow Posted January 25, 2004 Author Share Posted January 25, 2004 Thanks Andy, Here's the image, hope this helps sort my problem. Quote Link to comment Share on other sites More sharing options...
adhawkins Posted January 25, 2004 Share Posted January 25, 2004 It's a bit small...did you reduce it to 'avatar' size? There's no need for posting an image into a post. Andy Quote Link to comment Share on other sites More sharing options...
Black Shadow Posted January 25, 2004 Author Share Posted January 25, 2004 Getting the hang of this now, my first time posting so thanks for all the help. Quote Link to comment Share on other sites More sharing options...
Blatman Posted January 25, 2004 Share Posted January 25, 2004 Looks to me like the caliper is fully compressed, judging by the dust covers on the slider. Also, the caliper mount is nowhere near level with the lug it's gonna mount on. Have some faith, I reckon......... Quote Link to comment Share on other sites More sharing options...
ian_perry Posted January 25, 2004 Share Posted January 25, 2004 Your calipers look to be the right ones, just a thought but do you have the correct brake disks? As Leon B says they have a large offset, I'm almost sure mine have a larger offset than the ones in your picture - therefore bringing the disk further inboard IYSWIM The brake disks for the rear are escort Mk iii,iv,v front disks IIRC HTH Ian Quote Link to comment Share on other sites More sharing options...
Black Shadow Posted January 25, 2004 Author Share Posted January 25, 2004 Blatman, I've just tried to fit this again, I have taken another pic which might help expalin the problem. I did extend it but I'm sure these are not right. Have a look at this one, I might be doing something stupid .... Quote Link to comment Share on other sites More sharing options...
Blatman Posted January 25, 2004 Share Posted January 25, 2004 Er, the calipers mount outboard of the lugs, IIRC....... Quote Link to comment Share on other sites More sharing options...
ian_perry Posted January 25, 2004 Share Posted January 25, 2004 Must learn to type quicker! But after looking at your last picture I think I'm right.... you've got the wrong brake disks Quote Link to comment Share on other sites More sharing options...
Westfieldman Posted January 25, 2004 Share Posted January 25, 2004 There the WRONG discs the picture shows the correct ones front and rear you want the ones with the large offset. Quote Link to comment Share on other sites More sharing options...
Blatman Posted January 25, 2004 Share Posted January 25, 2004 Yup, ignore what I was saying. You have the wrong discs...... Good call fellas..... Quote Link to comment Share on other sites More sharing options...
