Kingster Posted September 20, 2020 Posted September 20, 2020 Anyone got one for a Brian James (micro max) trailer? I guess other makes could be adapted. Must be high level as the trailer is only ickle
Gary Taylor Posted September 21, 2020 Posted September 21, 2020 There’s a couple on eBay but there way down south
Kingster Posted September 21, 2020 Author Posted September 21, 2020 29 minutes ago, Gary Taylor - Scotland AO said: There’s a couple on eBay but there way down south Yeah too far and too expensive I think the same ones have been on there for months - don’t mind paying up to £200. 1
Simon Waterfall Syman84 Posted September 21, 2020 Posted September 21, 2020 chris you have the same trailer as me so that standard Brian James one doesn't fit its a different size. i found out the hard way
Kingster Posted September 21, 2020 Author Posted September 21, 2020 20 minutes ago, syman84 said: chris you have the same trailer as me so that standard Brian James one doesn't fit its a different size. i found out the hard way Thanks for the info Simon Have you got one now?
Kingster Posted September 21, 2020 Author Posted September 21, 2020 Winter project. Learn to use the MIG I have in the garage and make one 2
Martin Aldred - Shows & Events Coordinator Posted September 21, 2020 Posted September 21, 2020 Just be mindful especially if your trailer is single axle, most non 4 x4 tow bars have very limited nose weight limits. ( Mine are 80kg) Putting tyres Infront of the axle may overload your tow bar
Kingster Posted September 21, 2020 Author Posted September 21, 2020 1 hour ago, neptune said: Just be mindful especially if your trailer is single axle, most non 4 x4 tow bars have very limited nose weight limits. ( Mine are 80kg) Putting tyres Infront of the axle may overload your tow bar Yes - mines 75kg but figured I’d move the car back to compensate. Maybe an idea to test things first I guess!
Martin Aldred - Shows & Events Coordinator Posted September 21, 2020 Posted September 21, 2020 2 hours ago, Chris King - Webmaster said: Yes - mines 75kg but figured I’d move the car back to compensate. Maybe an idea to test things first I guess! Good idea. My trailers not long enough to have that option !!
Kingster Posted September 21, 2020 Author Posted September 21, 2020 Mine has a little leeway - but not much... so will likely make a rack that sits nearer the axle than the BJ ones. Should be room over the long bonnet.
Simon Waterfall Syman84 Posted September 22, 2020 Posted September 22, 2020 3 hours ago, Ben(EBD-ENG) said: this is also going to be my winter project well voluntold @RussH wants one as well so you might as well whip 4 up mate
TAFKARM Posted September 22, 2020 Posted September 22, 2020 I’m trying to blag one that’s hidden behind a tonne of compost
BenD Posted September 22, 2020 Posted September 22, 2020 you can or could buy pre bent bars from tube bender on ebay for the rack
