WillC Posted August 3, 2020 Posted August 3, 2020 Has anyone a pair of new unused zetec cams available. Standard will be OK as will any mildly uprated ones. Sadly my engine has scored journals on my standard cams so need replacements for the rebuild. Not really wanting to go to vernier pulleys and probably head will stay standard. Thanks
Wowblaauw Posted August 3, 2020 Posted August 3, 2020 You might want to see if polishing can help. I purchased some so called scored Pipers which all they wanted was a polish. if not I have a set of sub 1,000 mile cams if you want. cheers Craig
WillC Posted August 3, 2020 Author Posted August 3, 2020 Hi mate, I will look into that but one of the journals looks pretty scored up to me with others quite marked. What are your cams, standard? If they are unmarked may well be interested in taking them off your hands. How much are you looking for them? Regards
Wowblaauw Posted August 4, 2020 Posted August 4, 2020 Hi, they are completely unmarked as they were only in the engine for 1038 miles - the engine was a crate engine when installed. I have now upgraded to piper cams. How does £75 sound plus post. I'll get some images over to you later on.
andyj007 Posted August 4, 2020 Posted August 4, 2020 i have a set with 250 miles on them before being removed.. in december if wowblaauws are no good located colchester can post black top engine new in 2019
AlanHodge Posted August 6, 2020 Posted August 6, 2020 (edited) Oops Edited August 6, 2020 by WoodyAlan Wrong place
Retlendon Posted August 13, 2020 Posted August 13, 2020 On 03/08/2020 at 17:47, WillC said: Has anyone a pair of new unused zetec cams available. Standard will be OK as will any mildly uprated ones. Sadly my engine has scored journals on my standard cams so need replacements for the rebuild. Not really wanting to go to vernier pulleys and probably head will stay standard. Thanks I have a brand new pair of standard black top cams if you are still looking
WillC Posted August 14, 2020 Author Posted August 14, 2020 Hi, Hopefully just sent a message to you, interested in them. Regards
