FW LED Lights - Full set
AndySheldon
Looking for some help or someone selling a full FW rear light kit.
If someone can tell me the items i need to buy from Bowers.......I can then order from there.
Thanks in advance!
Link to comment
Thanks in advance!
@Ian Kinder (Bagpuss) - Joint Peak District AO knows at least some of the part numbers
Link to comment
He does indeed. Will post up ALL the part numbers. @AndySheldon is this before or after IVA?
Link to comment
If you buy the correct led lights they are suitable for iva so you only to buy them once
Link to comment
Hi @AndySheldon as @Rednop1 suggests, fit the correct lights once :praise:
The reason for my pre/post IVA question is I updated my FW rear end in Dec 2019 and removed the factory reflectors etc. Hence my suggestions would be different for post IVA etc.
The attached PDF shows the Hella part numbers and how I presented for IVA and how it looks now.
I bought all my upgrade LED units from Amazon. Sometimes they are on a long lead time and some times the price varies up and down. When I did order those items with a long lead time, they did fall and arrive a lot sooner than first published.
Opie Oils also stock them too: https://www.opieoils.co.uk/c-3367-hella-lighting.aspx
We may be able to help each other out!
I've got the items I've removed (i.e. the RED outer reflectors and RED Inner Reflectors)- They are as new and will pass IVA.
How about £15 for all 4? (plus postage).
I'm also about to remove my outer LED Clear/Lens Stop/Tail combined to update to match the inner pair I fitted in Dec 2019. These again are as new (provided by Westfield with my kit). The only reason for changing is the design has changed very slightly and being a perfectionist, I want them identical and I know they are different!.
How about £60 for the pair and I'll throw the two indicator lamps with Amber LED's in for free?(plus postage).
I'm also about to remove the outer clear indicator lamps. These again are as new and as provided by Westfield. I fitted LED lamps to them prior to IVA (decent items from Autobulbs Direct) and they've been great. The lens covers are slightly smoked and don't match the clear LED units I fitted in Dec 2019.
I fully understand if you want to buy new items, however as these are LED, they will last a very long time etc.
Make sure you only use very short stumpy screws as you can pierce the back of the items and moisture can get in- Don't ask me how I know. I'd even suggest to file the point of the self tapping screws to reduce the chances of it too.
I've just added a 3D printed pocket to sink the number plate light into the bodywork so it can't be seen from behind. I'll update my build thread later with details:
FW Rear light LED upgrade Hella Part numbers.pdf
Link to comment
Legend. Let's do a deal.......I'll pm you.
And thanks so much for the help!
Link to comment
Wonderful. I'll hopefully get to see them again, following you round the Peaks at some point when you've finished your S2000 too!
Link to comment
Oh you will! I'm just spraying my steering rack.
Got the bug now.
I'll pm you
Link to comment
