FW fuel tank, Frame, sender and straps.
As in the description, good condition.
This is the earlier model which I think carries 13L
collection preferred, but could post.
£200
@Carl Warren I'd suggest you check to help your sale, as I'm sure the latest FW tank is 27L and the earlier one like yours is circa 20L. @CraigHew can you confirm?
Appreciated, if Craig could help that would
be great.
be great.
If it's the original FW tank it's 20-21 litres
It is. Thank you.
Yup, ~21 litres to the brim...
PM Sent, assuming this will fit a Zetec SEIW chassis with the mounting frame I will have it.
There’s no fundamental difference in SEiW chassis between a ZK bodied car and an FW car, although later chassis have had extra mounts welded in as standard for the rear (optional) anti roll bar, in the FW position.
Dave thanks for the info, the chassis is 2007. When you say the chassis has extra mounts welded in as standard for the roll bar in the FW position, do you mean these extra mounts will foul the FW tank if an anti roll bar is fitted? or vice versa the tank won't fit with these mounts in place  (with or without an anti roll bar).
Thanks in advance for any clarification
No, the anti roll bar on a ZK body mounts higher up, on brackets the share the upper rear wishbone mounts, on an FW, the tank frame uses this mounting position instead. So the rear ARB is instead mounted where the fuel tank goes on a ZK car, there are a couple of brackets welded to the rear lower chassis rails for its mounting blocks to bolt to. These brackets, when not used, are underneath the ZK fuel tanK, so don’t get in the way. It’s quite a negative dual purpose solution. And if you wanted to fit an ARB at the rear on an older chassis that didn’t have the mounts, you could make some brackets up that bolted (or welded) on!
These brackets - for the Sports Turbo rear ARB.
Brilliant Jon, yes, that’s exactly right.
Sold 👍
