Clear out, ALL SOLD
Have some clearout stuff if of any interest.
160mm vdo dip tube fuel level sensor. Only 6 months old and only been fitted for 3 of those. It was the wrong depth sender for my tank. Same as this one (but cheaper at tweeks)
 https://www.merlinmotorsport.co.uk/p/vdo-dip-type-fuel-sender-160mm-long-224011000160g
£SOLD
1 x westfield upper inner column. Latest allegro style. Complete with boss bolt. £make an offer if they're any use
SOLD.
Steering lower column section. Standard escort size. This one https://www.carbuilder.com/uk/double-ended-splined-shaft
£SOLD
Set of 16 m12 tuner wheel nuts. Internal Allen drive. These are used and show signs of use as per pic £5
Standard switch connector tails, not sure if these are any use? Headlight, wiper, washer and fog switch tails. Flasher unit connector and a std hazard switch (but no connector tail)
£SOLD
Freewheel laser cut 8 button steering wheel plate. £SOLD
IVA wheel £Sold
20200424_170653_copy_3024x4032.thumb.jpg.6aec7244807e9115631f26e9c3940ba7.jpg20200424_170657_copy_3024x4032.thumb.jpg.f72f74eb9effd2f6c56d4b4c1065ded8.jpg
8 x eye bolts. All are schroth but only 4 still in packaging. £SOLD
Screen fillet. Dark green in colour, bit rough to be honest, it might sand back and polish up but will probably need a paint. SOLD
Cable Clutch pedal. £sold
Standard mirrors. They were a pristine pair until I dropped an eye bolt onto one and broke the glass. So one needs a glass. £Sold
All collected from Houston, renfrewshire or post at cost. If  you want any bits quickly I can courier at cost as royal mail are obvs running slower than usual.
Hi can we have the seat belt rings ,wiring terminals and screen trim how about  £25 + postage
Thanks chris and liz
@Liz03 you have pm.
I’ll take the upper and lower steering shafts, please!  Attaching bolt for
top not required....
You have pm @Charlie_Zetec
Hi Steve, if Liz is not taking the Hazard switch, just the wiring terminals, could I have it please.
Yep I've pm'd to see if they want the switch too. I'll let you know.
screen fillet, eye bolts, wiring tails and hazard switch provisionally sold to @Liz03
Upper inner column and lower 400mm shaft provisionally sold to @Charlie_Zetec
Clutch pedal now gone aswell.
@Charlie_Zetec @Liz03 your items were sent today :yes:
Iva wheel now gone.
Hi Steve, just PM'd you
:yes: mirrors now sold.
Removed the fuel sender today. My mistake but it actually seems its a 170mm sensor going by the part no and the overall length
Posted (edited)
dip tube now sold. Button plate sold.
Just the wheel nuts left.
Edited by Steve (sdh2903)
Updated
Hi Steve, I'll take the freewheel button plate please.
