I seem to remember a thread on this but can't find it, specifically re mounting when the rivets have pulled through the body work
M6 RivNuts and EPDM rubber stainless roof washers.  That’s how I fixed the complete body on mine..
Yup... Drill out the rivets in the chassis then install M6 rivnut. Stainless cap head M6 bolts with large stainless penny washers... 👍 You might have to pull the tub out the way to drill chassis.. Few wooden wedges hold it while you drill
Thanks for your replies chaps will give it a go.
You going to take the body off?
erm wasn't planning on taking the body off, just a repair to the rear fixing as the rivets have pulled through the body so its hanging 1/2'' lower one side.
If the body feels like its not keen on going back to its original shape at least if you do it with bolts you can bring it back up over a few days with shorter and shorter bolts.... and with the car in the sun warming the Fibreglass....
Thanks again for your input the body is not that far off so will rivnut and wind it back gradually.
