Header tank mounting bracket
I am after one of these Header tank mounting brackets I have got the tank if anyone has the bracket? thank you.
I just made one up yesterday, only a couple of quid of ally and some heat to bend it. Although I'll bet the Westfield  parts shop will have some on the shelf.
  • 2 weeks later...
That looks good what are the dimensions please before bending looks like 3mm thick
Yep 20mm wide by 3mm thick. Just put a rivet through the bottom where it overlaps.
