Zetec water pipe (hockey stick)
I'm after the pipe that connects the header tank and heater to the bottom of the rad I think it's called the hockey stick
Thanks in advance
Martin
Bump
Hi Martin,
From your description I don't think you are looking for a hockey stick but if you are I have one...
3 hours ago, Martin Rice (Sparkymart) - Cornwall AO said:
Hi @Tim (TimDave25) - Joint Thames Valley AO thanks for your reply
I think you might be right the pipe I need is only about 15mm . Any idea what it's called ?
Cheers Martin
I'm not sure the name of the other one except it's a 15mm pipe with one outlet to the header, one to the heater and one near the rad. I replaced mine with silicone hose and joiners but got rid of it years ago.
The pipe above is 32mm with 15mm takeoffs.
I didn't have the heater at this time but gives you the idea.
Hi Martin is this the pipe your after?
and as fitted on my car
John176E8EEF-94A6-4B9D-B67C-57BD699082A7.thumb.jpeg.0b474fdb075e4c0503b0cac409229c5b.jpeg
Tim that's kind of what I've got at the minute but using 15mm copper pipe and hose
Thanks John that's what I was after but looking at that photo I'll still need another pipe for the thermostat bypass .I thought it was built into that one
