Mark Stanton Posted December 28, 2003 Share Posted December 28, 2003 Tried and tested work fine in a Westfield, parts readily available can still perform with the best ......... Just ask "The voice of reason" Rob Navin or Rocket Ron Siddle They're still getting good times in the Speed Series with X-flows (when not blowing em up ) There's one for sale for just £3500 on this boardroom - sounds tidy from the description and worth having a look at X-flows can be leaky but that can be sorted Quote Link to comment Share on other sites More sharing options...
Major Stare Posted December 28, 2003 Author Share Posted December 28, 2003 To sum up then:- -they blow up -they leak oil -they can be quick -cheap -old sounds bleedin great !!!! Quote Link to comment Share on other sites More sharing options...
Matt Seabrook Posted December 28, 2003 Share Posted December 28, 2003 To sum up then:- -they blow up -they leak oil -they can be quick -cheap -old sounds bleedin great !!!! Quote Link to comment Share on other sites More sharing options...
Rob Navin Posted December 28, 2003 Share Posted December 28, 2003 To sum up then:- -they blow up -they leak oil -they can be quick -cheap -old sounds bleedin great !!!! Now Jon It once again fall on me to point you in the right direction. To answer your points from above. Yes they can blow up, normaly if you let Ron drive them. But then all engines can do that and the X-flow is no worse than any other. You have to treat them like you would any other engine. They can leak oil as can any other engine. You can stop it by not putting oil in them but this does make them blow up more often . They can be made to not leak though if you use the right bits. They are quick, there are plently of supposedly better engines that are slower when it comes to the times. Are you sure your driving is quicker than a X-flow car ? They can be cheap or they can be expensive. A replacement for mine would be about 8k with no bolt on bits but you can get them cheaper than most other engines as they are not as fasionable as a 16v unit. Can't argue with old but they are still easy to get parts for them. And yes, they do sound great and in a westy they do go very well. If you want to come over and have a good look at what a good X-flow car can be give me a shout. Cheers Rob The Voice of reason Quote Link to comment Share on other sites More sharing options...
scott beeland Posted December 28, 2003 Share Posted December 28, 2003 They are quick, and in a westy they do go very well. Rob The Voice of reason But only when you let "the rocket" double drive Quote Link to comment Share on other sites More sharing options...
Major Stare Posted December 28, 2003 Author Share Posted December 28, 2003 Cheers for the offer Rob, i'll be in touch. My only concern is my knowledge of the X-Flow is less than say a K, VX or Vetec unit. Are there any signs to look for, i.e. 1.6 or 1.7, bored out, cams etc etc? Quote Link to comment Share on other sites More sharing options...
Major Stare Posted December 28, 2003 Author Share Posted December 28, 2003 Rob, Sent a PM, but got a reply saying your on holiday????? Quote Link to comment Share on other sites More sharing options...
Rob Navin Posted December 28, 2003 Share Posted December 28, 2003 Hi Jon. Just got it at home mate. It's just the work e-mail that I'm not answering. I will give you a ring on Monday. Cheers Rob Quote Link to comment Share on other sites More sharing options...
