Rear Carbon stone guards - extra wide rear arches
On 05/02/2019 at 07:36, Chris King - Webmaster and Joint North East AO said:
I vinyl wrapped mine before I found some carbon guards, was easy enough to do and looked ok. It offered minimal protection, but certainly better than none
Swapped my metal ones out as they where goosed and wanted a more modern look and realised It does not make a whole lot of sense using carbon fibre to cover pockmarked grp with loads of rivet holes. Looks good though.
Carbon NV is got to be the shout but not many wide arches are there?
6 hours ago, Chris King - Webmaster and Joint North East AO said:
Pretty sure @Andy (Sycho) did something similar for cage protectors albeit with easier shapes.
Yes I made some cage protectors using a carbon skinning kit, I taped  up the cage so i could remove it once it had cured. Not sure how you would do that with the arch.
