ASH Need an alternative supplier for stainless pipe?
Guys . Ordered a 32mm diameter 90 degree bend pipe at 300mm long ,but unfortunately ASH have no stock and no re order date.
Any alternatives you can suggest?
Did an eBay search and only found AP who stock ASH.......
Happy to source from eBay or somewhere near Northwich.
Would like stainless ideally but happy to listen to alternatives as it might only be temporary use.
It's only a £10 part so don't want to go too far.
Thanks Jon
Does it have to be stainless? Polished aluminium is usually more common.
Having found ASH poor in the past, I’ve generally used VIper, they have a 32mm aluminium pipe here, https://www.viperperformance.co.uk/aluminium-pipes_9819_90-aluminium-hose-joiner.html
its 152x152 mm leg lengths if that would do.
Note, if you need an elbow with one leg longer than the other, Vioer have also recently introduced some super long versions, to allow you to cut them down to suit, (BLiNK have a bead roller to redo the end that you trim). Each leg is 300mm.
super long elbows, here.
https://www.viperperformance.co.uk/aluminium-pipes_10199_super-long90-elbow-aluminium-hose-joiner.html
Try a local exhaust builder - There's a branch of Longlife close to you
Unit B12 Deeside Industrial Estate
Deeside
CH5 2JZ
Telephone 0151 268 0533
The will sometimes have pre-formed sections in stock (rather than the crush-bends that you'll get if they use their bending machine to form the bend
Perfect thank you. Will place an order. I will be cutting it to make it an s shape with a rubber joining hose. Thus bead roller suggestion really the complete answer. Thank you.
Nigel the Deeside suggestion great thanks, will store that one, sure ill need it in the future
Cheers Jon
Ramair on ebay also do alloy bends . Not as cheap at ASH but they do turn up in a day or two.
