Sump Gasket
Turns out the Sigma doesn't have a gasket as such for the sump, it's sealed with silicon.
But what silicon?
Any recommendations?
Any quality gasket designed for sumps. We Honda boys use Hondabond which is the mutts .............
Welcome back Thrusty....
Id normally always go with the manufacturers own for key joints like that, that can be prone to leaks etc. However, as TJ says, (fantastic to see you back @Thrustyjust ), Hondabond is fantastic stuff! It’s a bit of a faff to apply, as it’s quite thick and hard going to squeeze out, it also has quite a short handling time compared to the average RTV, but in all other respects, it’s hands down the best gasket compound I’ve ever used. Honda must use it for pretty much all the major castings on the S2000 short block.
