conibear Posted December 7, 2003 Posted December 7, 2003 Just thought if anyone's considering doing a Duratec installation into a SEIW, then here's a couple of pictures of mine. At the bottom is how I did it and what the spec is. The engine developement was undertaken by Raceline. It has a Raceline wet sump and water rail. Crank & pulley keyed. Pistons pocketed, high lift stage II cams, Throttle bodies, Weber alpha ECU, AP heavy duty racing clutch, ultra light flywheel, and a 4-2-1 7" silencer. It utilises the standard Mondea starter motor, standard water pump, lightweight alternator, Caterham engine and gearbox mounts. It is in a SEIW MT75 chassis but fitted with a T9 close ratio heavy duty track gearbox which enables the engine to go back a lot and thus uses a short prop-shaft. It also has a 4.1 LSD. It produces 226 bhp @ 7250 rpm. If anyone has intentions of doing this and wants me to answer questions, please fire away. Cheers Ian Quote
Petrol.Head Posted December 7, 2003 Posted December 7, 2003 Is it a 1.8, 2 or 2.1 Litre Duratec. I would love to see the pictures but they don't appear on my PC I was talking to Raceline about doing the same thing with a 1.8 engine. Have you tried the car out yet ?. Did the car have another engine in it before the Duratec or is it a new car ?. If so it would be interesting to get the before and after weights as the Duratec should be a lot lighter than a Ztec or a VX. Quote
conibear Posted December 7, 2003 Author Posted December 7, 2003 As far as I know Duratecs only come in a 2 litre or 2.3 litre form, mine is the 2 litre. It is a new engine and new car, so it's being run in and car not had SVA yet, but I have driven it and seems lively. The engine is 20-30kg lighter than Zetec or VX, I don't know weight of car yet, but will post when known. Cheers Ian Quote
SteveD Posted December 7, 2003 Posted December 7, 2003 if your running it in ,how do you know its producing 226 bhp @ 7250 rpm Quote
conibear Posted December 7, 2003 Author Posted December 7, 2003 The same spec was at Weber's factory under developement for their ECU, they produced 226bhp on their rolling road back in October, the same spec is in a Stylus (orange) see kitcar november issue. A caterham recently recorded over 230 bhp with the same spec. Ian Quote
SteveD Posted December 7, 2003 Posted December 7, 2003 so it could be 230 bhp , could be more when the engine free's up a little etc Quote
SteveD Posted December 7, 2003 Posted December 7, 2003 well i didn't like to say but yes it does mr mason next on the list tidy up engine bay Quote
windy Posted December 7, 2003 Posted December 7, 2003 Kin el Makes my engine look tatty Might be tatty Ash but yours is an engine that delivers the goods. Are you ready to run!!!!! Nice colour!!! Quote
conibear Posted December 7, 2003 Author Posted December 7, 2003 Raceline guarantee 225bhp so realistically thats what it is and its only a Catering van that could have more "with the same spec". I heard this "catering van" sold for £28k last month I do hope mine delivers the goods and it will be ready to run Jan 2004, Windy Unfortunately, I can't run the car on slicks with the wet sump, not until the dry sump kit's available (spring 2004). Quote
Petrol.Head Posted December 7, 2003 Posted December 7, 2003 Ford do a 1.8 Duratec as well as the 2 and 2.3 Litre. I was told that Racelines first mock up engine at the Autosport show last year was a 1.8 Litre. Minister use the 2.3 in their High Torque Cateringvan engine. PS. your pics are now up and OK Quote
windy Posted December 7, 2003 Posted December 7, 2003 Here's a picture of a nice engine fitted to a Ford Quote
SteveD Posted December 7, 2003 Posted December 7, 2003 i didn't realise matt had gone for vx power Quote
windy Posted December 7, 2003 Posted December 7, 2003 i didn't realise matt had gone for vx power Yep he's moved over to the dark side Quote
SteveD Posted December 7, 2003 Posted December 7, 2003 errrrm yes its very f****n dark where you pair are you can't beat the classic lotus t/c Quote
