KIERAN Posted December 7, 2003 Share Posted December 7, 2003 Questions on behalf of someone else, as many replies as possible please to get a general opinion. On a X-flow with 40's would you think that it would need a choke cable or not, we are discussing setting carbs up and cold start e.t.c. Do you have a choke on yours? Whats the score with gear lever extensions, are they available and if so where from. (type -9 5 speed). Thanks all, please reply could do with a general opinion Quote Link to comment Share on other sites More sharing options...
Rob Navin Posted December 7, 2003 Share Posted December 7, 2003 Kieran. In the old car with the 244 cam and running twin 40's I did run a choke for the early morning cold starting. It just made things a bit easier. With the new cae running a Mass cam and twin 48's I have not bothered as it dosen't get started in the cold mornings. Gear lever extensions are from Westfield themselves. I don't have one fitted as I feel that cars with them on don't have as direct a feel to the gear change, and been slighlty larger than norm I don't have a problem reaching the gear stick just under the dash. HTH Rob Quote Link to comment Share on other sites More sharing options...
Turbo Tommo Posted December 7, 2003 Share Posted December 7, 2003 been slighlty larger than norm Quote Link to comment Share on other sites More sharing options...
TAFFYY Posted December 7, 2003 Share Posted December 7, 2003 Hi Re.Carbs yes do conect choke cable,as for the gear lever leave as is Tom Quote Link to comment Share on other sites More sharing options...
Blatman Posted December 8, 2003 Share Posted December 8, 2003 A wide body car *must* have the gearlever extension fitted if the engine is going in the standard position. The extension *will not* fit in a narrow car without moving a chassis rail. I have never used a choke on Webers, and unlike my big boned, knuckle dragging friend up there, I do go out in the cold....... Quote Link to comment Share on other sites More sharing options...
Buzz Billsberry Posted December 8, 2003 Share Posted December 8, 2003 I find the gear extensions crap as do most other people but thats just my opinion..but I'm never wrong! Buzz Quote Link to comment Share on other sites More sharing options...
felters Posted December 8, 2003 Share Posted December 8, 2003 I've just dumped my choke cable as I was putting a new dash in and couldn't see the point in keeping it there. Well below freezing this morning and it started a treat! But hey! It's a Toyota (sounded worryingly Blair like there for a few seconds....) Quote Link to comment Share on other sites More sharing options...
7SE Posted December 8, 2003 Share Posted December 8, 2003 I've got 40s on a x/flow with a Type 9 gearbox. I have no choke fitted, and never felt the need. I have the Westfield gearshift extension, and would not remove it. Quote Link to comment Share on other sites More sharing options...
KIERAN Posted December 8, 2003 Author Share Posted December 8, 2003 That helps, Cheers guys. Kieran Quote Link to comment Share on other sites More sharing options...
