Throttle bodies
Long shot I know, but does anyone happen to have a set of throttle bodies on a zetec manifold gathering dust anywhere? Thought I'd ask before I start the Ebay searching...
Jenvey sell manifolds for £200 plus the vat. I after talking to Martin at Raw am going to use standard injectors and fuel rail as per the zetec or the fuel side and modified weber 40's for the air. Cheaper than going throttle bodies and will look good to.
I never thought about modifying carbs for the air intakes. Would certainly look good. Is it much of a job?
Just a case of blocking all the jets up really
Do you need to re map due to more air flow and fit a throttle potentiometer to butterfly spindle
Chris and liz
It will need mapping and a TPS yes
I have a set of 45mm Jenvey ITBs that I am going to sell. You would need a manifold but if interested send me a pm.
james
