mr_mcp
SEiW 2.0 Zetec - 185BHP
After much deliberation, I've made the decision to sell my fantastic Westfield after 6 years of cherished ownership. I'm planning to undertake an Ultima build, so sadly this must go.
Full spec listed below:
ENGINE & DRIVETRAIN
2.0 litre Ford Zetec engine (new piston rings fitted <4k ago)
Twin Weber carbs with a pipercross sausage filter (recently serviced)
Fully ported head (recently skimmed and valves etc fully serviced, at great expense!)
Balanced crank
Kent Cams FZ2002 Sports camshafts
Dunnell lightweight flywheel
Dunnell lowline baffled sump
High efficiency radiator
ASH silicon hoses throughout
Alloy catch can
Malpassi Competition Filter King Fuel Pressure Regulator, Gauge & Filter
Heat wrapped 4:1 exhaust manifold
Wunoff re-packable exhaust filled with acoustafill (95dB)
Dyno tested at 185bhp and 156 lbs/ft torque at the back wheels (Pulls hard from virtually any revs)
RS2000 alloy bellhousing
BGH Geartech E7 Pro road & track Type 9 close ratio gearbox - Ratios: 2.66, 1.75, 1.26, 1.0, 0.84
Quaife ATB limited slip diff (lifetime warranty)
New half shaft UJs recently fitted
RUNNING GEAR
Wilwood Dynalite 4 pot calipers and uprated discs and pads on the front (fluid recently changed)
Standard drums at the rear (lightweight compared to discs and very effective on such a light car)
Genuine magnesium alloy 13" Minilite wheels
Toyo R888 tyres (GG compound). 205/60/13 at the rear and 185/60/13 on the front.
Adjustable Spax coilovers
Nylon suspension bushes
Bespoke rose jointed front upper wishbones
Full suspension geometry setup and corner weighted - brilliant on both road and track.
Weighs only 580Kg dry with full wet weather gear, so less with the aero screen setup and no heater etc.
INTERIOR
JK Composites seats with 5 piece padding set
and red piping
4 point harnesses
Carbon effect panels on the rear bulkhead and transmission tunnel
Aerodynamix carbon fibre dash
Brown & Geeson (official MOMO) quick release steering boss
Sparco suade steering wheel
Starcom intercom
12V power socket
EXTERIOR
Aerodynamix carbon fibre aeroscreen (which retains the same fixings used for the full screen. Makes for easy switching between screen setups should you wish)
Carbon-NV rear diffuser with added strakes
Carbon-NV ducted CSR style cycle wings
Full LED rear light units with carbon effect housings
Carbon effect boot lid
Carbon effect wheel arch protectors
Carbon effect centre and wing mirrors
Carbon effect nosecone canards
Carbon effect LED front indicators
MSA approved LED rear rain light
RAC roll bar
Quick release nosecone fixings
Bodywork in great condition for age. Minor repair carried out on drivers side rear arch where the previous owner ran over a traffic cone (about the size of a 50 pence piece) which you can't notice unless you look closely. I have the colour matched gel coat and hardener if you wish to tidy-up further.
BAD BITS - as reflected in the sale price
(Very) Minor oil leak - will lose less than a teaspoon over the course of a month
Chip on the rim of the pass front alloy (can be seen in the pics - cosmetic only)
NOW RESOLVED -- Occasionally the starter motor won't engage fully. --
Sailed through the MOT last week, so will come with 12 months. Fully serviced with massive history and receipts.
Asking price £9,750 £9.5k ono
Full asking price will include the following, if desired:
Full screen with pillars and integrated wing mirrors
Wipers and wiper motor
Heater and silicone hoses
Side screens
Tonneau cover
Original dash
Original front indicators
Original rear lights
Breathable indoor car cover (some slight wear and tear)
Please message directly or call for further info 07737352805, based in Swindon.
Share this post
Link to post
Can anyone tell me where to get the rear diffuser from please :yes:
Share this post
Link to post
Carbon-NV
It's a top quality item, would highly recommend
Share this post
Link to post
On 12 August 2018 at 16:39, mr_mcp said:
Carbon-NV
Thanks :yes:
Share this post
Link to post
Thanks for the kind comments gents :yes:
I went for a drive last night... Was meant to be a quick one, but had too much fun and stayed out for 2.5hrs, I'll certainly be sad to see it go to the next lucky owner.
A couple of snaps from my outing:
Share this post
Link to post
Starter issue now resolved
Share this post
Link to post
Please, no time wasters, serious enquiries only (I've had a few now!).
Share this post
Link to post
Thank you! Sure, which ones are you referring to?
Share this post
Link to post
Price reduced
Share this post
Link to post
