Hello all,
Does anyone have the part numbers ( Quinten Hazel etc )for SEW front top and bottom suspension ball joints? If not part numbers what the original  fitment was? Cortina, Escort, Sierra etc?
Top ball joints Quinton Hazel QD1117RHT
Bottom Ball Joint Quinton Hazel  QSJ663S
They're the same as I used. The track rod ends are Mk 3, 4, 5 Cortina, FTR4040, if you need those.
They are a ford transit drag link with right hand thread....don't ask what age transit, I have no idea!
@Jonk179 I've recently replaced my top ball joints courtesy of help by @Robin (Red Spider) - Yorkshire AO and the numbers he's given are correct.  Track rods are for cortinas mentioned and the upper ball joints fit standard and wide track Westfield front suspension wishbones. I quoted the part number given for upper ball joints and my supplier mustn't have been able to obtain so supplied frontline FTR4701 these are also good for the job too.
Can't help with lowers as never changed yet but will watch these posts for all options.
Scott
Di knew you knowledgeable folks would see me right. I'm going to order these on Monday. Looking to rebush all the suspension at the same time and fit new shocks and springs. Any advice about which suspension bushes to go for? Also SEW front/rear shock lenghths and Spring pound ages. CVH engine and passenger and I quite like pies!
If you need steering rack gaiters, I used SRG047 and SRG200. I had to get 2 sets as they were different side to side.
Thanks Robin I will probably change the gaiters at the same time as the cost is minimal. Have you changed your suspension bushes?
No, just the joints, but I might be able to help you out. I'll check tomorrow.
I'm not sure as I didn't change mine, but I was told that the bushes are Hillman Avenger outer track control bushes, QHY 976. Can anyone confirm?
  • 1 month later...
Evening,
Can any of you helpful chaps confirm that the codes quoted are also correct for a 92 SE narrow?
The numbers I put up are correct for my 1991 registered car.
Here is an old but very helpful resource here
Thanks both.
A while ago a few of us contributed to a slightly updated parts list:
Gary
