4age power?
I have recently purchased an Seiw with a 4age motor, twin dellarato 45s and an omex 3 dimensional ignition. It’s been standing for quite a while and has hesitations when first opening the throttle but clears at high revs?!? Totally new to these cars and carbs, what to try first?
Also what power output could I expect for such a set up?
:ww:    There's a couple of 4age powered around.     Hesitation could be a lot of things but the 45 carbs are a little large for a 1600cc engine.     You could start buy giving it a service, all the usual things, oil,filter, air filter, spark plugs and if your keen rebuilding the carbs with a service kit from Eurocarb, which includes all the gaskets, O rings, filters.    After that a carb tuning specialist may be able to jet it correctly and have it running a bit smoother.
As for bhp, anything from 140 to 160 at a guess.
45's are too big for the 4age you would be better off with twin 40's ask Martin at RAW for jet sizes he's really helpful. Bhp about 140 ish
I made 148 with my 4age on twin 40’s
Can’t remember weather mine had 40’s or 45’s I thought they where 45’s, but it was all susplied by raw & was the same set up as yours. I remember them changing the jets when they set it up & it was a cracking engine but as said service change plugs etc.
Standard they where about 135bhp & if you had up rated cams 160bhp
Any pictures?
  • 2 weeks later...
The car was misfiring badly when I bought it, changed plugs and leads etc and it’s much better, just a this hesitation when first opening the throttle but when it clears it pulls very well. I did wonder if the carbs were to big and needed more air?
  • Like 3
It'll just need the carbs setting up. Will be a goer then.
  • 1 year later...
After life getting in the way, spent a bit of time and money and it is now running a healthy and smooth 130bhp after a carb tune. New tyres and tracking and now running great.
  • Like 7
There you go, just needed a little love and attention.
Looks great, I imagine pretty light too?
