Kevin (Mr T) Posted June 4, 2018 Posted June 4, 2018 I am after a cordless impact wrench, not too expensive and would appreciate any recommendations. Quote
Terry Everall Posted June 4, 2018 Posted June 4, 2018 I have had a Sealey 2400 for 4 years but the 24v battery is failing now and a new one is about £100!!!! Quote
Mike Rowland - Essex AO Posted June 4, 2018 Posted June 4, 2018 You just know I'm going to always recommend Makita 18V 1/2" impact with 2 x 4.0Ah batteries, so you can start buying all the other naked Makita tools... Quote
Kevin (Mr T) Posted June 4, 2018 Author Posted June 4, 2018 2 minutes ago, Kit Car Electronics said: You just know I'm going to always recommend Makita 18V 1/2" impact with 2 x 4.0Ah batteries, so you can start buying all the other naked Makita tools... You are a nightmare! Having said that, I just might, it is fathers Day soon after all, even if they never know they bought it for me Quote
Mike Rowland - Essex AO Posted June 4, 2018 Posted June 4, 2018 3 minutes ago, Kevin (Mr T) - Essex AO said: You are a nightmare! Having said that, I just might, it is fathers Day soon after all, even if they never know they bought it for me Start small and build up. 3 Quote
Kevin (Mr T) Posted June 4, 2018 Author Posted June 4, 2018 1 minute ago, Kit Car Electronics said: Start small and build up. Back corner of your garage? Quote
Mike Rowland - Essex AO Posted June 4, 2018 Posted June 4, 2018 Hmm. Makita Impact Driver, Combi Drill, SDS Drill, Circ saw, trim saw, Recip saw, Multitool, Hedgetrimmer, vacuum, leaf blower, jigsaw, sander, strimmer, pole trimmer... You might be right Quote
Kingster Posted June 4, 2018 Posted June 4, 2018 1 hour ago, Kit Car Electronics said: You just know I'm going to always recommend Makita 18V 1/2" impact with 2 x 4.0Ah batteries, so you can start buying all the other naked Makita tools... Yep. Makita all the way. I’ve only got 2x 3Ah lxt batteries but works for me. Got 4x tools but more will get added - naked of course Quote
BenD Posted June 4, 2018 Posted June 4, 2018 What power should I be looking at for an impact driver for removing wheels nuts and stuff Quote
Thrustyjust Posted June 4, 2018 Posted June 4, 2018 2 hours ago, Kit Car Electronics said: Start small and build up. Until you realise they all come in the same sodding Makita blue cases and you have to spend the day opening every one to find the 'right' tool and then put them all away afterwards. 1 Quote
BenD Posted June 5, 2018 Posted June 5, 2018 11 hours ago, terry everall said: 24volts? do you have alink to the one you have terry im owndeing what sort of NM power i require to take wheels off and on Quote
Deanspoors Posted June 5, 2018 Posted June 5, 2018 Just to be the voice of opposition.... DeWALT!! 2 Quote
Peter (Monty) Posted June 5, 2018 Posted June 5, 2018 @Deanspoors that is the only real answer I have a DeWalt 18V impact driver, I bought a bare unit as it uses the same batteries as my drill. I'd recommend using the same make as your existing tools to avoid investing in an extra set of chargers and batteries. What makes do you have already? Quote
