If only I could find a similar set-up for nose cones!
Just a thought in the interests of damage limitation, what do you do about the rear light wiring?  New connectors?
John
Generally when the wing comes off the connector plugs will become parted from the loom wires  :(  ;)  then either re-use old connectors if still intact or get some new ones  :D
These items are generally small cost in comparison to a new arch  ;)  :)
What about a aluminium strip (curved of course to match shape of arch) and used on the tub - like a single large washer - then use nylon bolts and small washers on the arch side - i would have thought this would leave the tub intact ???
cheers
chris
