What trestles have people bought for their builds ?
the Westfield ones looks a tad dear for what they are but if there are most suitable then I’ll order some.
or if anyone has any left over they would like to sell ?
I like "playing" with wood, so made my own from timber I had laying about. Advantage of being wood was I easily shortened them as my build progressed.
Easy if your reasonably proficient at woodwork, just satisfy your self they're strong enough, adequately braced, and stable.
Started off like this:
Now ended up 13" tall, high enough for me to be able to easily slide under the car. And i find is a comfortable height for "tinkering", and saves my back!
Ended up like this:
Ended up like this:
This looks a great solution although I’m not sure my joinery skills are that great.
I may enlist a friend to help.
There’s always been a Club tradition over the years of passing the Westfield Build Stands on to other users once your done with them yourself. There used to be a few sets in circulation at any one time. That said, it does seem to have tailed off a bit in recent years.
Shame really.
I built some like Adges. Easily modify-able. One thing tho. I'm just in the process of adding heavy duty castors to gain a bit of room when not building.
I was given a set which I forwarded on after my build. but to be completely honest, I only used them for a couple of days and then swapped to 4 axle stands as I found it easier to work on the car at a lower level (I'm 5'9" before somebody asks if I'm vertically challenged!).
Ian.
I've got a set of Westfield stands you can have FOC.
I'm based in Marlow and I see you're in Wetherby but I will be close to the southern end of the Humber Bridge around 11:30 this coming Saturday if that helps.
Any good?
The trestles suggested by Bugman may actually be more flexible. Like others I found 4 axle stands worked better for me, but I'm 5' 6"
Have axel stands as well, although seen some builds all the way to rolling on tresseles
Thanks for the offer guys but I’ve committed to buy some from the classifieds now.
