WSCC Blyton 2018 Trackday and Booking Info - 13th July 2018
Regardless of weather, I have stocked up on supplies
Not a piece of salad made it into the trolley :d
  • Haha 2
Is that cheese I see under the buns... :suspect:
  • Haha 1
Good news re the Track Day and the issues we had with the briefing and cracking on with the day last year an be found in the below post:
Indeed it is :laugh:
11 hours ago, tkm_dave said:
What ECU is it? Might be someone with a spare that can copy the map over to it. Just need to consider the possibility of any potential loom faults killing that ecu too depending on what the symptoms are with your current ecu.
Get this.
I have an Omex 600 which is some super fancy special commision version, where you cannot take the map from it once saved....
So I contacted Northampton Motorsport who did the map and they didn’t save it either....
Spoke to omex who said if I replace my chips with the standard items I might be able to get the map from it.
So I’ve bought a new ECU to pull apart in the hope I can liberate the Map and then rebuild the new ECU so it might work.
Wish me luck.
  • Sad 1
3 hours ago, KugaWestie said:
I much prefer the BBC forecast
Met office is not too bad...
Nice to see its cooler ooopp north, will be a nice rest bite :d :sun:
Cooler! That’s positively tropical :d
and it’s darn sarf!
Cars still not running.
Will be a late one tonight...
New map, crank sensor and coil pack on the way.
YOU WILL RUN.
YOU WILL RUN.
Good luck mate.   Sounds like a PITA..
Is it possible to have a separate briefing later in the morning?
My car is still being worked on and possibly won't be ready until 9am so I'm not going to make it to blyton until mid morning (If at all) :(
Does anyone know what is the latest time I can turn up tonight to camp? I think the gates are locked at a certain time...but can find any details?
cheers
Dean
It is. I'll still come along and work on the car in the pits. It may come to life during the day.
Many thanks for all those who organised today's track day.
The briefing was good and concise, the weather was good, great company and overall I had a great time! :)
Thanks also to Adam for his help with my set up.
Hope all goes well for the sprint weekend.
Steve
cheers
Dean
Gates locked at 10pm
