Compression tester
Anyone local to Nottingham got a compression tester I can borrow? If not, can you recommend a decent one that's not too expensive.
Scott
Is it for an S2000, I only ask, as they’re quite deep set spark plugs, so it would need to be reasonably long reach.
Never tried mine on the Honda! (Won’t get a chance to till next week either, I’m afraid). Mine was OK on the deep set XE plugs on my previous engine, so I suspect might be a alright.
It's tricky to get the hose to screw in square and you don't want to strip the threads in the head :cry:
I just tightened it by hand as best I could.
I'm in Derby..I have  one you can borrow.....or drive over and we can check it 'while you wait'
Cheers. I'll take you up on that offer :t-up:
When is convenient for me to pop over?
Is it worth checking and adjusting the valve clearances first before you do a compression check
Possibly, that's a bit beyond my capabilities though.
It's fairly easy. See attached.
valve clearance.pdf
Does next Saturday work for you?.... we can move if it's raining
valve clearance.pdf
I can confirm on it not being difficult, but you will need bent feelers for the inlet ones as its a real ball ache to get round the inlet manifold. If I had thought about it, I should have done it before putting in the car as would be a so much easier.
Didn’t ‘operation yewtree’ Lock up all the Bent Feelers :p
I now  recall I did mine with the engine on a stand with no manifolds so didn’t have this issue :yes:
  • Haha 1
