graham frankland Posted December 12, 2017 Posted December 12, 2017 Looking for the Radtec Aluminium Rad, direct replacement for the usual Polo version! Anyone got one please? Graham (Glutey)
Onliest Smeg David Posted December 12, 2017 Posted December 12, 2017 Coolex http://www.coolexperts.co.uk do choice of direct replacements. Most Off the shelf.
graham frankland Posted December 13, 2017 Author Posted December 13, 2017 Dave Thanks I will check them out! Glutey
Onliest Smeg David Posted December 13, 2017 Posted December 13, 2017 Me and many other members have had great service from them. I got the 55mm Polo rad, nice quality.
graham frankland Posted December 13, 2017 Author Posted December 13, 2017 Dave Do you have any idea on what sort of temp differences you have achieved? Trying to understand the extra benefits of the 55 mm v 42 mm core? Any info greatly received! Thanks G
Onliest Smeg David Posted December 13, 2017 Posted December 13, 2017 Compared with my original Polo rad, Temperatures appear to run steadier. As in less up and down, and fan doesn't have to cut in as often. High and Min temps unchanged.
Deanspoors Posted December 13, 2017 Posted December 13, 2017 I have a coolex rad and intercooler on my Megabusa, can see it in my profile pic... it's big and heavy! the fan feels a bit weak too, but all in all it works so far.
Kingster Posted December 13, 2017 Posted December 13, 2017 I have a coolex 55mm. Temps are rock steady and once hot never strays more than a few degrees. Order direct and mention the club for a discount.
Nic Chase (NICO) - Shropshire & Mid-Wales AO Posted December 14, 2017 Posted December 14, 2017 Another one for Coolex 55mm. Good price, quality and service. As Chris says mention the club for a discount.
graham frankland Posted December 14, 2017 Author Posted December 14, 2017 Thanks Guy's My Polo rad has only a 30 mm core so do I need to go to 55 mm or will the 42 mm be sufficient? Any input appreciated! Thanks Glutey
Craig Spooner Posted December 14, 2017 Posted December 14, 2017 42 mm Works for me, same engine as your good self
Onliest Smeg David Posted December 14, 2017 Posted December 14, 2017 1 hour ago, Craig Spooner said: 42 mm Works for me, same engine as your good self Can't get much better than that then glutey
Dave Eastwood (Gadgetman) Posted December 14, 2017 Posted December 14, 2017 3 hours ago, bunje said: if you go too big you may end up overcooling Doesn’t seem to be the case in practice. The difference between the 70mm core and the 55mm, seems almost counterintuitive at first. If anything, in slow traffic, mine actually runs a little hotter at first. - With the old 55mm core, as soon as you got to around forty mph or so, temps would start coming down to the stable running temperature nice and quickly. - With the 70mm core, I don’t get the same effect till at least 60 mph; I’m guessing it’s the restrictions caused by having the extra row, needing more air pressure differential across the radiator. However, once the 70mm does see good air flow, it does indeed cool the engine back to normal running temp faster than the old 55mm used to. (I have a high power road fan, that moves plenty of air, so equally, with the 70mm core, it can bring temps down again nice and quickly). The 55mm won’t be as restrictive compared to a 40 odd mm rad, as my 70 is to a 55, but it does make me think, go for the thinnest that works!
